Old 04-15-2007, 03:07 AM   #961
Trader Rating: 8 (90%+)
Sounds like the Pro38's.
Johnny Carey is offline   Reply With Quote
Old 04-15-2007, 07:44 PM   #962
B&B Racing's Avatar
Send a message via AIM to B&B Racing
Yup!
djb
Sponsered by BJ & Z Hobbies.
B&B Racing is offline   Reply With Quote
Old 04-16-2007, 04:24 PM   #963
wallyedmonds's Avatar
are they purple gray or are they somthing different.
wallyedmonds is offline   Reply With Quote
Old 04-26-2007, 11:50 AM   #964
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Any update on when the GenX manual will be available for download?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 04-26-2007, 12:02 PM   #965
R/C Tech Charter Subscriber
Send a message via AIM to acyrier
If it's possible to "2nd" a question... I 2nd that one.
The products and places I support.
www.michianarc.com www.facebook.com/michianarc - www.russellrc.com
www.teamtekin.com - www.teamcrc.com - www.teamassociated.com
www.fantomracing.com - www.discountrcstore.com
acyrier is offline   Reply With Quote
Old 04-26-2007, 08:51 PM   #966
lmgdao i totally forgot about that
manual we dont need no stinking manual.
Old 06-23-2007, 05:25 PM   #967
bump from the grave...
Are you guys still having trouble with the lower arms breaking, or did CRC redo some stuff?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 06-23-2007, 05:57 PM   #968
losi guy's Avatar
Trader Rating: 38 (100%+)
Send a message via ICQ to losi guy
Another bump, use the 3mm graphite ride height spacers it will cure your problem. I bought tons of arms that will last me probably two years because they kept breaking. i have not broke a arm since i put those graphite spacers on.
Spektrum | Avid | DE Racing | Tekno
losi guy is offline   Reply With Quote
Old 06-23-2007, 08:27 PM   #969
so CRC hasn't changed anything then?
www.freerice.com
Old 06-24-2007, 12:40 AM   #970
There was a material tweak late last season. Once you ditch the red washer/spacer in favor of their graphite spacer, the arm is rarely breaks. You really have to get into the wall hard to break the arm when using the graphite spacer.
insideline is offline   Reply With Quote
Old 06-24-2007, 09:07 AM   #971
The only reason they were breaking was because the screws would not thread far enough into the arm. The graphite spacers required a lower ride height and therefore would allow the screw to go further into the arm.
Longer screw and/or the graphite spacers pretty much fix the problem.
Old 06-25-2007, 09:56 AM   #972
Trader Rating: 21 (100%+)
The graphite spacer will fix the arm breaking problem. It gives support to the arm and does not let it flex in a hard crash. I run the same size tire as before and put a shim under it to get ride height the same as before. Have not broken one arm since using the spacer. Same screws and everything.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 07-02-2007, 06:46 AM   #973
alana07's Avatar
Trader Rating: 52 (100%+)
Send a message via MSN to alana07
anyone here knows the front wheel bearing sizes for the Gen X ? has the CRC website gone kaput?
没有最好,只有更好!!!
alana07 is offline   Reply With Quote
Old 07-02-2007, 07:24 AM   #974
SuperRooster's Avatar
Send a message via AIM to SuperRooster
Default bearings
3/16 x 5/16 Flanged bearing
http://www.teamcrc.com/crc/modules.p...prodID=7718951
This should be what you need.
SuperRooster is offline   Reply With Quote
Old 07-02-2007, 07:12 PM   #975
alana07's Avatar
thanks pal...
没有最好,只有更好!!!
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
