Old 03-20-2007, 03:52 PM   #916
Pat Clark's Avatar
i just counter sunk the graphite spacer and used longer screws, so that the screw goes thru the spacer, arm and castor block... That if i do break an arm i dont have to have a drill and counter sink for every arm
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
Old 03-20-2007, 03:55 PM   #917
edseb's Avatar
Originally Posted by wallyedmonds
graphite piece on the servo saver dose change the ak in the steering
shock the other way for air bubblys in the shock
graphite spacers under the arms so the arms dont break
and counter sink the arm for the 2 screws for the upper block so they sit flat on the spacers.
Depends on what side you put your graphite piece. I have mine on the opposite side of the saver from the ball stud.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 03-20-2007, 03:59 PM   #918
wallyedmonds's Avatar
if you put it on on the back you haven't changed anything
on the front you change it a bit.
wallyedmonds is offline   Reply With Quote
Old 03-20-2007, 04:02 PM   #919
no, you want the full surface flush.
this iv found anyways works the best for impact.
i am waiting for the new front bracing that looks realy sweet.
Old 03-20-2007, 04:28 PM   #920
Pat Clark's Avatar
the full surface does sit flush graphite to chassis and arm.. I dont think you understand what i said in the first post
Old 03-20-2007, 04:32 PM   #921
OH YES sorry
hmmm that seems cool
but dose it make it kinda hard to change the ride hight.
Old 03-20-2007, 04:38 PM   #922
Pat Clark's Avatar
OH YES sorry
not at all the spacer is bolted to the arm.. the front arm screws go thru the spacer in the arm.. If you use the crc height adjusters that are cut, just lossen the arm screw a few turns and slide in or out the thin spacers..Even with a 41 mill front tire the graphite never comes out..
Old 03-20-2007, 04:40 PM   #923
LOL yes i just thot of that
hmmm i may try this
how long are the screws.
Old 03-20-2007, 04:48 PM   #924
Pat Clark's Avatar
hmmm i may try this
arm screws are the same, you use the longer screw in the front castor block hole (originally in the rear hole) and you need a 2 mill longer one for the rear hole...
Old 03-23-2007, 03:07 PM   #925
I can't stand to see this forum on the last page.
jackh is offline   Reply With Quote
Old 03-23-2007, 04:43 PM   #926
arr see car's Avatar
Location: West Ozzie living in Merrigum...Shepparton...Victoria
Default Buying a Gen-X
Where is the best place to get the gen-x from who ships overseas.
Can't find anyone in Australia who sells them.
There's a coulpe of us who want it
...Current Toys...
.....(: WIFE :)......
.MST MS-01D Pro.
....Axial Wraith....
arr see car is offline   Reply With Quote
Old 03-23-2007, 08:56 PM   #927
clint's Avatar
Trader Rating: 24 (100%+)
Send a message via MSN to clint
I have a gen-x on the way.
any good set up help for stock on carpet?
www.rcottawa.com TRF EVO 5.5 Exotek V2, TRF 419X, RSD RR12 V2
PR/HP PRS1 V1,V2,V3 FM, PR/HP PRSB401
http://hobbyauthority-dist.com
http://www.maclan-racing.com
http://www.pr-rc.com/
clint is offline   Reply With Quote
Old 03-23-2007, 09:44 PM   #928
Michael.H's Avatar
i would also like to know.
Synergy N9, OS91SZ-H, Hatori SB18, JR DS8711's, JR G770T, ATG, Arizona Reg.
T-Rex 600CF
T-Rex 450SE x2
RC12L4
FlightPower LiPo's all the way.
Michael.H is offline   Reply With Quote
Old 03-24-2007, 02:45 AM   #929
get a gen x from crc direct
Old 03-24-2007, 05:45 AM   #930
A little late but Odpurple, your car looks fantastic. The wiring detail is particularly trick. I saved the images for futher use. Thanks!
catcars is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
