Old 12-26-2006, 06:51 AM   #481
James,
Nice and clean looking. Your right, it doesn't look balanced.
Kevin
KevinL is offline   Reply With Quote
Old 12-26-2006, 07:12 AM   #482
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
What kind of roll out should I start with on a small/med size track using a 19t? I plan on using the Checkpoint money.
Dasupacat1 is offline   Reply With Quote
Old 12-26-2006, 07:13 AM   #483
akura2's Avatar
Send a message via AIM to akura2 Send a message via Yahoo to akura2
I REALLY like that bumper... someone should make that in lightweight impact-resistant plastic as well...
akura2 is offline   Reply With Quote
Old 12-26-2006, 07:17 AM   #484
wallyedmonds's Avatar
start at 48 if you have a kd try 47
wallyedmonds is offline   Reply With Quote
Old 12-26-2006, 07:18 AM   #485
that would be better and it may not brack the chassis.
Old 12-26-2006, 07:23 AM   #486
Dasupacat1's Avatar
I forgot to ask about spring setup.
Old 12-26-2006, 02:16 PM   #487
James35's Avatar
Originally Posted by carkillaii
Damn good lookin Ride , what rod ends are you using?
They are Lundsford Racing titanium turnbuckles. Sorry, I don't remember the size.
I'm also using Dubro ball links at the servo, and will soon be adding them to the steering blocks as well. You'll want the 256/4-40 version at the servo, and the 4-40/4-40 version at the steering blocks. They greatly reduce the slop compared to the usual ball cups. Order extras because some of them come out the package better than others. I pick the best ones and have no extra slop at all with this method. Althougn, even the average dubro links with some slop is much less than your typical ball and cup. With the servo laid down flat, I don't even need the cones. If you do use cones on the 4-40 links, pick up these aluminum ones to save weight. I used the 4-40/4-40 dubro link on the center shock as well. Makes removal of the shock easy. I will be replacing the other one as well. (I have more on order).
Originally Posted by Fast Faisal
Why lay the servo down instead of on mounts?
Fast Faisal
Less weight, lower center of gravity. I've always run the servo flat, and never tried it angled (other than for my oval cars). And from my research about people's opinion on running it flat, it seems to suit my driving style and track conditions.
James35 is offline   Reply With Quote
Old 12-26-2006, 02:39 PM   #488
im still running green but alot of ppl are running red or gold. on a checkpoint idono the springs are different and not to many ppl run this motor,it seems a little slow but i dono.
Old 12-26-2006, 04:00 PM   #489
Exclamation RE....GENX
After reading all 17 pages I have decided to order my GENX, to replace my 3.2R. Thanks for the post Kraig.(KT Hobbies) I think I got your last one. As to the QC problems I have read, they seem fairly minor, although I do not find the excuse of a time factor acceptable for poor QC. But I'm an old fart and I believe if your going to do it, do it right.
I also saw a couple of posts with a modified GTB speed control.(fan and heat sink removed) Removing the fan is a no brainer, Now the heat sink is another story!!!!! I have my new GTB sitting on my bench, Where can I have it modified, or is that something I can do myself????? All help is appreciated, Thanks.
TJ
THEBIGBULL is offline   Reply With Quote
Old 12-26-2006, 04:46 PM   #490
wvince's Avatar
Location: Tupperville, Ontario, CANADA - like tupperware but with a population of 450.
Modifying the GTB yourself is very difficult as the cloth transfere tape between the aluminum plate and the fets rips very easily. It would be best to send it back to Novak and request it made into a 4 cell version or exchange for a 4 cell version.
The obvious, you would need to make an aluminum plate. The 4 cell GTB will be available the first of the new year.
www.gsrhobbies.com
hudy
Novak
CRC
wvince is offline   Reply With Quote
Old 12-26-2006, 06:58 PM   #491
Look like the small Du-bro ones
-E
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 12-26-2006, 11:42 PM   #492
Scottrik's Avatar
Trader Rating: 245 (100%+)
Doing the steering linkages as shown I use the 2-56 ball link (4-40 rod) DuBro ends at both ends. The Lunsford turnbuckle that works easiest is the 1-3/8" set as they are threaded closer to the center "nut". You can cut down the standard 1-3/4" set but you end up cutting the ball links shorter because you don't have as much thread to work with.
The most challenging part (though certainly not brain surgery) was making little bushes out of 1/8" brass tubing for the screws into the steering blocks.
Scottrik
Scottrik is offline   Reply With Quote
Old 12-27-2006, 05:26 AM   #493
Dasupacat1's Avatar
Do you guys use any damper fliud on the front suspension? I rememberusing on the CK but it's been soo long. I don't remember which viscocity I used.
Old 12-27-2006, 08:30 AM   #494
Trader Rating: 45 (100%+)
I think most are using the CRC Medium lube, CRC Heavy lube, AE 10K and\or AE 30K and then some are running no lube. I guess it all depends on what your car is doing and making feel right for you.
Apex is offline   Reply With Quote
Old 12-28-2006, 10:32 AM   #495
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
My parts came back from the anodizer today
I'll post pics when I get it totally together....this car is going to look SO sweet!
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
