Old 12-25-2006, 08:41 PM   #466
R.Dalnogare's Avatar
Send a message via AIM to R.Dalnogare
Originally Posted by Kraig
Hey guys, if you are looking I have a couple of Gen X kits left. Get them before I close the doors for good.
Kraig
KT Hobbies
YGPM!
R.Dalnogare is offline   Reply With Quote
Old 12-25-2006, 08:55 PM   #467
Scottrik's Avatar
Trader Rating: 245 (100%+)
Kraig--was sure sorry to see you're calling it a day. Hopefully it's a change that will ultimately result in good things for you and yours.
Scottrik
Scottrik is offline   Reply With Quote
Old 12-25-2006, 08:59 PM   #468
Scottrik's Avatar
Originally Posted by acyrier
I also saw earlier in this thread that the kit came with "blue" tube lube? the tube lube that came with my kit had a "white" cap, which I thought was light, red was heavy and blue was medium. I should probably recheck my stuff. When I saw it was a white cap, I just used hwat I already had instead of opening another bottle of it.
The red cap is "light" (what all the 3.1-3.2 kits came with). The white cap is "heavy" and the blue cap is "extra heavy". iir, that came about because there was only "light" and "heavy", then they decided to introduce a heavier lube yet but didn't want to confuse anyone who was already using the red or white cap versions. What would have made sense (ultimately) was to rename the white cap "medium" and call the blue "heavy", but I believe the decision was made with consistency in mine.
Scottrik
Old 12-25-2006, 09:10 PM   #469
wvince's Avatar
Location: Tupperville, Ontario, CANADA - like tupperware but with a population of 450.
Not sure what exact setup to use at the Magma race. I haven't run the Gen-X at Fastcats yet. I would start with the copper shock spring, red or green side springs, .50 front springs, 30 wt oil in the shock and set the caster to 2 shims back. Fastcats is a fast, flowing track. There are a couple bumps that the T-bar cars will notice. But the Gen-X will drive smooth on this track.
The side springs are red with a pink rear and magenta front tire.
There is more clearance on the damper tubes of the Gen-X compared to those of the 3.x series cars. Therefore a heavier lube can be used to acheive the same dampening. This helps with consistancy.
www.gsrhobbies.com
hudy
Novak
CRC
wvince is offline   Reply With Quote
Old 12-25-2006, 09:56 PM   #470
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
What are you guys using as spacers for a transponder up front? My used GenX didn't come with anything.
Dasupacat1 is offline   Reply With Quote
Old 12-25-2006, 11:19 PM   #471
James35's Avatar
Default Finished building my Gen-X
Well, I finished building my Gen-X today. Here it is. Click the picture for a higher resolution image.
It doesn't look balanced 50% / 50%, but it is. Can't wait to try it!
James35 is offline   Reply With Quote
Old 12-25-2006, 11:26 PM   #472
someone else is bound to ask, so I might as well. Who makes the bumper?
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 12-25-2006, 11:33 PM   #473
James35's Avatar
Hyperdrive HP-1127. Picked it up at RC4Less, but I can't find any more.
The 2 front screws are designed for 8-32 screws, so I drilled another through the bumper and used a triangle effect to keep it tight. I dremmeled out some for the transponder too. I did all the modifications to the bumper.
Old 12-25-2006, 11:37 PM   #474
Trips's Avatar
Trader Rating: 16 (100%+)
I used three Associated front end pivot balls from an old strut front end I had laying around.
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-26-2006, 12:22 AM   #475
Where can I find part number 13615 Red LP Ball for sale? I can't find it on CRC's website. Also how about the Red Aluminum Ball Studs?
Tony Vega is offline   Reply With Quote
Old 12-26-2006, 12:53 AM   #476
fraz's Avatar
Send a message via AIM to fraz
Not sure what you mean on the first part, but the second part should be this http://ashfordhobby.com/detail.aspx?ID=4511
fraz is offline   Reply With Quote
Old 12-26-2006, 02:18 AM   #477
carkillaii's Avatar
Damn good lookin Ride , what rod ends are you using?
carkillaii is offline   Reply With Quote
Old 12-26-2006, 06:30 AM   #478
wallyedmonds's Avatar
this is about what im running at fastcats but i do like black white tires, red side springs most us green and the blue cap lube on the tubes(what wt is this anyway)id like it to be thicker, cant handle the magenta fronts
wallyedmonds is offline   Reply With Quote
Old 12-26-2006, 06:32 AM   #479
the front lower arm balls
Old 12-26-2006, 06:43 AM   #480
Why lay the servo down instead of on mounts?
Fast Faisal
Fast Faisal is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
