Old 12-22-2006, 06:43 AM   #421
wallyedmonds's Avatar
Originally Posted by rc_bam226
The red low roll center ball is not yet available on the site.
it in a different spot. some parts are the same as the 3.2
wallyedmonds is offline   Reply With Quote
Old 12-22-2006, 06:50 AM   #422
Originally Posted by jackh
What seems to be the tire ('s) of choice for most of you and what size do you cut them to the first time.. (For carpet).
Jack
purple,grey is ok black,white is good im gona try purple white next magenta in the front are way to gripy for me,but i know some guys like it. im also gona try purple pink, and this is all CRC tires. but right now white black are my fave.
Old 12-22-2006, 12:11 PM   #423
Default Bearings
Does the GenX come with Metric bearings? I need to replace them and I am unsure which bearings I need.
jackh is offline   Reply With Quote
Old 12-22-2006, 12:13 PM   #424
rc_bam226's Avatar
All the bearings are in inches. What bearings are you looking to replace?
rc_bam226 is offline   Reply With Quote
Old 12-22-2006, 12:56 PM   #425
Default Bearings
I am going to replace them all. The rears are gritty and the fronts are not much better.
All for now
Jack
Old 12-22-2006, 12:57 PM   #426
rc_bam226's Avatar
Alright for the fronts they are 3/16" x 5/16" flanged bearings, the rear has 1/4" x 3/8", you'll need 3 flanged ones and 2 non-flanged ones. Hope this helps.
Old 12-22-2006, 03:42 PM   #427
fraz's Avatar
Send a message via AIM to fraz
Originally Posted by G Ace
My local track (CRC Raceway) has the transponder loop on a "bridge" above the track instead of under the carpet also. All I needed to do was mount the transponder with the label facing up (instead of down) on top of two 1/8" plastic shock spacers, and it counts fine.
If you need to get it even higher, you can mount it on 2 short threaded stand-off posts.
That is exactly how I has mine mounted when it wouldn't count right, hmmm. I'll probably switch it back for the upcoming NWCC race because it's under the carpet.
fraz is offline   Reply With Quote
Old 12-22-2006, 04:00 PM   #428
fraz's Avatar
Originally Posted by dr_hfuhuhurr
I'm looking at setting up my electronics in the GenX now. Here's a question/request:
The ABP battery braces, especially the first one. I could probably take about 1/8" of the material on the front edge of that to allow more room for electronics.
Anyone see any problem with this?
Is this part even necessary?
I shaved mine down about that much because I originally started the car with a large Spektrum Rx. It fit perfect behind my KO-949 servo. I now have the Spektrum mini Rx so it's not an issue.
Yes I think the part is necessary. Even with it, I have "missed" a corner at speed and once had my cells jump out. The extra height on that lip is required. Or if you tape your batts you could probably get away without it.
Old 12-22-2006, 04:17 PM   #429
Trader Rating: 28 (100%+)
Send a message via AIM to omaha_racing
all the bearings are the same size as a 10th scale pan car. Only exception would be the front wheel bearings. Check out http://members.fbx.com/~rmurdock/win...ion_Parts.html
Hes has ceramic's for 35.00 a set. Ultra fast shipping also.
B-Fast R/C
omaha_racing is offline   Reply With Quote
Old 12-22-2006, 11:40 PM   #430
All for now
Jack
aps has a very good set for this car or you can use the crc ones
Old 12-23-2006, 02:01 AM   #431
James35's Avatar
OK, got my kit in (over 1 month wait). Overall, I'm impressed with the build quality and instructions are great. Individual bags per assembly step make assembly easy.
A couple of things that could be improved:
The football 256 flat head screws are too short. They just barely have enough threads to hold.
The adjustable battery holders need a lot of material removed in order to make the batteries fit (I tested with 3800 and 4200's). If using the batteries in the forward position, you'll have to remove material off of the middle tab on one of the battery holders because it hits the football! Whats with that? This extra middle tab doesn't serve any purpose anyway.
Yep, the motor pods ride height openings are the largest I've seen. I had to spend some time and superglue multiple coats around the outer oval edge, being careful not to get it on the back edge, or else it would prevent the ride height adjuster from sitting flush and flat.
My right side hub is not true! It wobbles on the axle pretty bad. Putting a tire on exaggerates it, but you can even see it when spinning it by itself on any axle. I tried 2 other hubs, different bearings, and confirmed the CRC right side hub is the problem.
The left side hub is a joke. Weighs more than a tank. It's quite obvious that CRC has a bunch of these on hand, and are trying to get rid of them with their kits. It's the red version of this:
I'm throwing it in the garbage and replacing it with something like this:
My bevel spring washer for the diff is bent. And it's too big to fit a tire over anyway. Again, not sure what CRC was thinking here.
My kit (from the recent second Christmas batch) did not come with brass set screws designed to prevent damage to the kingpin threads.
One of my Torpedo tubes came without the threaded opening. Click attachment below. CRC is sending a replacement.
In summary, I like it overall, and I'm looking forward to driving it. CRC has some quality control issues, tolerance issues, and a few design issues.
James35 is offline   Reply With Quote
Old 12-23-2006, 05:56 AM   #432
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Where can you get those hubs?
Dasupacat1 is offline   Reply With Quote
Old 12-23-2006, 06:15 AM   #433
Trips's Avatar
Trader Rating: 16 (100%+)
Those are made by Irrgang (IRS).
http://www.teamirsrc.com
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-23-2006, 08:30 AM   #434
vtl1180ny's Avatar
R/C Tech Charter Subscriber
I swapped the IRS axel off my 3.2 onto my GenX
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-23-2006, 08:34 AM   #435
Dasupacat1's Avatar
which part #'s?
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
