Old 12-20-2006, 01:19 PM   #406
wallyedmonds's Avatar
Originally Posted by Scottrik
That's a pretty broad statement. They might give you proper width if you're using the kit wheels, but you'll likely not be using Jaco, TRC, etc wheels/tires and I'll bet money you're 1/4"-ish narrow if you're using Parma wheels/tires...
Scottrik
oh yes this is true im just using crc tires right now oh and the shims are .38 on my car 1 on the left and 2 on the diff side but yes if your using different tires than it will be different shimming, it was on my L4, from trc to parma.
wallyedmonds is offline   Reply With Quote
Old 12-20-2006, 01:21 PM   #407
Originally Posted by vtl1180ny
Try getting 50/50 wieght distribution running a GTB!!!!
no problem. I can do it without adding any weight.
Davenport is offline   Reply With Quote
Old 12-20-2006, 01:29 PM   #408
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
What is the part number for the side link balls? I can't find it on the CRC site.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-20-2006, 01:36 PM   #409
Blake
Red Low Roll Center Ball #13615
One Piece Link #1380
Old 12-20-2006, 04:42 PM   #410
rc_bam226's Avatar
The red low roll center ball is not yet available on the site.
rc_bam226 is offline   Reply With Quote
Old 12-21-2006, 10:59 AM   #411
Default Tire of choice
What seems to be the tire ('s) of choice for most of you and what size do you cut them to the first time.. (For carpet).
Jack
jackh is offline   Reply With Quote
Old 12-21-2006, 11:16 AM   #412
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Jack
I'm going to need to go to a softer tire combo, the Grey/Purple isn't giving me enough traction, probably going to drop to Pink/Magenta...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-21-2006, 01:06 PM   #413
Grenade10's Avatar
Trader Rating: 37 (100%+)
For out track - High Elevation - Lots of Snow today - Ozite Med Grip -
I've gone to Black fronts and White rears. The Magenta fronts / Pink Rear has also worked, just did not fit my driving style.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-21-2006, 01:59 PM   #414
Anthony.L's Avatar
Trader Rating: 36 (100%+)
My favorite recently is also White rear/Black front, in CRC Pro-Cut's.
Anthony.L is offline   Reply With Quote
Old 12-21-2006, 04:19 PM   #415
How do the compounds compare from these three... Jaco, Parma and CRC? Is a pink, white, gray, purple, black compounds the same shore, rubber makeup with all three companies?
One of the reasons I'm asking is. I was running Jaco White Rears. Traction was great for 6 to 7 mins and then lap times started to slow down and the car started to get a little unpredictable. Also the tire wear was .5mm per 8 minutes. The good thing with running these tires I picked up very little carpet fibers.
When I ran Jaco Pink rears the traction was great!! Tire wear was less than .5mm per 8 minutes even better. The big problem with the pinks is that I would pickup so much carpet fiber I would turn my axle bearing into bushings after one heat?
Just didn't know if there were any compound in between Jaco whites and pinks? from other companies?
Thanks, Greg
Old 12-21-2006, 07:21 PM   #416
I'd like to have the car before I give you my thoughts! Anyone know where I can get one. I live in Utah and all the shops are currently at the mercy of their suppliers.
daveb is offline   Reply With Quote
Old 12-21-2006, 07:55 PM   #417
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
How small do you guys run your CRC procuts before you toss em? I believe new they are 1.9 and 1.8'.
Dasupacat1 is offline   Reply With Quote
Old 12-22-2006, 03:19 AM   #418
Is the GenX a good option to run on asphalt?
Wascheck is offline   Reply With Quote
Old 12-22-2006, 06:38 AM   #419
i run them till there is no more foam to the rim i say, or you can say , to the CA
Old 12-22-2006, 06:40 AM   #420
on line from CRC and you can get parts that way too. and tell there supplier's to get the thing,they wont be sorry.
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
