Old 12-18-2006, 02:47 PM   #376
Trader Rating: 45 (100%+)
Originally Posted by akura2
Thanks... that thread is almost a year old... half the pics are missing... and most of the ones that are left are body-off... I set up a thread for both body-on and body-off pics of recent cars... so feel fre to post
and thanks for the link.. there are some setups in there that I can get some ideas from
Here is Blackstock's. Probably one of the cleaner layouts I've seen out there considering he's running a receiver pack.
http://teamcrc.com/crc/images/storie.../MB-car_01.jpg
Apex is offline   Reply With Quote
Old 12-18-2006, 02:51 PM   #377
wallyedmonds's Avatar
here's mine, anyone else
CRC's New Generation-X.... Your Thoughts?-dscn1679.jpg   CRC's New Generation-X.... Your Thoughts?-fscn1681.jpg
wallyedmonds is offline   Reply With Quote
Old 12-18-2006, 05:47 PM   #378
wally no wonder that car is slow no motor or tires
but at least its not on fire
just joking buddy
Lou
look is offline   Reply With Quote
Old 12-18-2006, 06:59 PM   #379
just joking buddy
Lou
LOL
Old 12-19-2006, 09:58 AM   #380
Default Twitchy under acceleration.
I love this car. I just have issues with it under acceleration. I cant get it to go in a straight line when I hit the gas. My car has an Associated front end and I am running a 19 turn motor, with purple fronts and gray rears. Ride is about 4 mm and the front end tweak is correct. Copper center and white rear springs. I have ordered the original front end for the car to give that a try. I am not sure what front springs are on it. When I purchased the car they were already installed. (Second hand car). The car just has way to much steering for me very quick response, Twitchy. I can get it to push by take out center spring preload however doesn't seem to make the acceleration problem go away. I have cleaned all the bearings and made sure the car rolls free. The battery is in the forward position. I am looking for any suggestions on what I can try to eliminate this problem. I must also mention I am new to 12th scale. I am used to running pan cars and my XRay TC.
Thanks for the help
Jack
jackh is offline   Reply With Quote
Old 12-19-2006, 10:08 AM   #381
rayhuang's Avatar
jackh Heres a few thngs to check for the pulling.
-Tweak. Lift car from center of chassis from front or back of pod and make sure both wheels lift at exactly the same time.
-preload on side springs is equal
-preload on front spring (or no preload or droop) is equal per side.
-axle is centered in rear pod.
-tires are very nearly equal diameter per side
-chunk in one sidewall of rear tire, but not the other
As for it being twitchy:
-make sure circles are equal size and then make them bigger by 0.5' and try again.
-heavier front spring or softer center or softer side or lighter dampening in side tubes or hvy lube on front king pins.
-harder front or softer rear (black or purple Parma fronts and pink rears)
-softer oil in center shock (not a big change).
-more caster
-less camber
-less toe out
Old 12-19-2006, 10:08 AM   #382
James35's Avatar
Have you balanced the car for a side-to-side 50% / 50% weight distribution?
James35 is offline   Reply With Quote
Old 12-19-2006, 10:27 AM   #383
Grenade10's Avatar
Trader Rating: 37 (100%+)
Rayhaug - Nice list of items!!
I second the underlined item - check that the the distance from the centerline of the chassis to the outside of the rear wheel is the same on both sides. I have a STUPID amount of shims in my car. Also while you are at it get the car to the max rear wheel width, you will not be sorry.
On the "Twitchy" stearing, you might also try a wider front track, as my re-flexes have slowed down with, yes, age. It has really helped!!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-19-2006, 10:45 AM   #384
Sorry for my stupidity but is there a knotch or a mark that denotes the center line of the chassis? As for ballanceing, do you achive 50/50 by moving things around or by using your perload screws on the rear springs? And what about front to rear weight. Thanks for all the help guys.
Jack
Old 12-19-2006, 10:50 AM   #385
Gael L's Avatar
Which shims are you using to adjust rear track width?
Gael L is offline   Reply With Quote
Old 12-19-2006, 11:04 AM   #386
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Try getting 50/50 wieght distribution running a GTB!!!!
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-19-2006, 11:51 AM   #387
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
lol
Old 12-19-2006, 12:49 PM   #388
I have seen a bubble balancer in the pits of others. Who make them?? HUDY?
Old 12-19-2006, 12:54 PM   #389
Super Moderator
Marcos.J's Avatar
http://www.hudy.net/eshop/products/p...0&kategoria=64
Old 12-19-2006, 12:55 PM   #390
rayhuang's Avatar
Jack
Take a straight edge down the center of the car using the screws for the antennae and football screw or whatevers down there and mark the front and then the rear. I use a hobby knife and make a slight V and then fill it in with a silver sharpie-but methods can vary.
Ray
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
