Old 11-28-2006, 01:24 PM   #241
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Originally Posted by smyka
white side springs two turns down for top of plate then tweak
Smyka, when you say two turns down I'm assuming you back the side spring set screw all the way up till it's bottomed out on the top plate. Then two full turns down toward the bottom plate correct?
Anthony.L is offline   Reply With Quote
Old 11-28-2006, 05:48 PM   #242
Grenade10's Avatar
Trader Rating: 37 (100%+)
Smyka - what front blocks on the Gen-X for 19 turn?
Thanks!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 11-29-2006, 07:04 AM   #243
johnnywhopper's Avatar
he means 2 turns of preload. 2 turns down from all the way out is not enough to make the car return to center.
run your springs down to where they just barely make contact with the bottom plate on each side, then add 2 turns to each side. set tweak from there.
john
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 11-29-2006, 09:24 AM   #244
Trader Rating: 45 (100%+)
Default Tire question...
What CRC Pro-Cuts are equivalent (or the closest) to Jaco Double-Pinks?
Apex is offline   Reply With Quote
Old 11-29-2006, 09:37 AM   #245
G Ace's Avatar
Send a message via AIM to G Ace Send a message via Yahoo to G Ace
Magenta
G Ace is offline   Reply With Quote
Old 11-29-2006, 12:45 PM   #246
smyka's Avatar
Send a message via AIM to smyka
anthony you had it right dont listen to whopper he is only good at setting my foot ball straight grenade10 i always run 10 degree blocks unless the track is high speed with a lot of swoopy corners
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 11-29-2006, 01:19 PM   #247
he said swoopy giving you a call now
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 11-29-2006, 01:40 PM   #248
G Ace's Avatar
I was going to say... turn the springs down to flush and THEN 2 more full turns??? That would be waaay too much preload. Mark, you should also mention if you are using 3mm setscrews and the plastic spring holders (AE shock pivots), or 4-40 screws and the aluminium spring holders. 2 turns of a 3mm screw is a lot different than 2 turns of a 4-40 screw.
Old 11-29-2006, 04:35 PM   #249
smyka's Avatar
gary if you bought a new car instead fo taking old scraps you would know the new car only comes with 4-40 set screws and the alum. spring things
cuffs you like it swoopy dont you see you in a week and half
Old 11-29-2006, 04:39 PM   #250
ill be there u bring carissa or did she get too good lol
Old 11-29-2006, 05:04 PM   #251
smyka's Avatar
she is comming dont knowwhat classes she is running
Old 11-29-2006, 05:26 PM   #252
smyka - you're out of your mind. 2 turns and the spring doesn't even touch.
maybe if you preloaded your springs a little more, carrisa wouldn't have ran your azz down from almost a lap back.
we'll see who's 2 turns works better at the Jam. lol.
ace - 2 turns isn't too much preload, just like 2 laps down to me isn't too much either.
jw
Old 11-29-2006, 05:28 PM   #253
Originally Posted by Scottrik
The front axles are 3/16". Yup...just another one of the reasons I sold my two on. I'm all for change that makes sense, but at the point change is made for change sake is when I step off the bus.
I just received my Gen-X... wow, what a car! Well beyond any other 1/12th car in my opinion.
I am really happy to see they kept the O-ring, taping is a real pain in the butt. I found the kit went together very easy. You can feel that this car is really manufactured from the ground up, not some conversion kit or an hodge-podge of parts from various manufactures.
I see here talk about the old front end... WHY? this new front end is the slickest, easiest, most user friendly pan car front end to date. It is super smooth right from the start, I didn't have to polish a thing. I guess people like setting caster and camber with pieces of paper and cardboard (old front end?) or maybe people like fiddling for hours trying to get the left and right sides equal...(current Associated)??
The front axle size change... it is obvious why CRC changed the axle size... so that the front axle can switch from inline to trailing axle. It looks very similar to Associated's inline oval axle. to me it looks like change for the sake of technology, ease of use and performance, not just for the sake of change. The technology bus you're stepping off is about to run you over.
CRC should be commended on a great kit. Now if they would just get rid of this black and white assembly manual... give us some glossy color. Also, we need a starting set up.
fasterform is offline   Reply With Quote
Old 11-29-2006, 05:30 PM   #254
smyka's Avatar
im telling you whopper try it they just touch with two full turns maybe thats your problem hahahahaaaaaaa
Old 11-29-2006, 06:39 PM   #255
stonedgti's Avatar
Trader Rating: 15 (100%+)
The car looks awesome, and I would love to get one. Only gripe is that the QC from CRC is pretty bad with this first batch. My LHS got 5 cars in and 4 of them had parts or screws missing. One of them was missing diff balls. 4 out of 5...man that's really really bad QC! Hope the next batch won't be like that.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
CRC's new GENX10 younghovaa Electric On-Road 3 02-08-2008 06:13 PM
WTB generation X ltrdude R/C Items: Wanted to Buy 0 12-15-2007 06:03 AM
*CRC Generation-X samstheman2 R/C Items: For Sale/Trade 6 10-08-2007 06:27 PM
CRC's New Clik-Trak Barrier System KyLayfield Electric On-Road 30 09-19-2007 04:35 AM
CRC Generation X Lextek R/C Items: For Sale/Trade 1 05-25-2007 04:22 AM
