EFRA decision. 5 cells -1350gr >
Old 01-05-2007, 07:22 AM
  #436
Ali Graham's Avatar
My T.O.P Scythe weighs in at 1340g ready to go for dry racing, and 1370 with waterproofing for the oh so common rain
Ali Graham is offline
Old 01-05-2007, 07:55 AM
  #437
kentech's Avatar
Originally Posted by HappyHippo
Are the Much More tires the same as sorex? since they have the same nr 28/32/36
The Much More tyres are not the same as Sorex.
It is a lower profile tyre than both Sorex and VTEC.
kentech is offline
Old 01-05-2007, 08:02 AM
  #438
HappyHippo's Avatar
Is it the same type of rubber?
HappyHippo is offline
Old 01-05-2007, 09:35 AM
  #439
I know of at least one factory Tamiya driver who has machined the bulkheads hollow aswell as other alu parts to get it under 1350 with brushless...a bit extreme, but shows it can be done.
Jan Larsen is offline
Old 01-05-2007, 09:39 AM
  #440
Oh and yes, the Much More tires are not the same as Sorex as kentech said. Lower profile and more grip actually than sorex 28 and CS22.
But 30 runs and they're shot...on carpet...
Old 01-05-2007, 09:45 AM
  #441
Holmenkollen's Avatar
Wich danish TRF driver could that be who has access to a machineshop?
Holmenkollen is offline
Old 01-05-2007, 10:26 AM
  #442
You prolly only need one guess
Old 01-05-2007, 11:52 AM
  #443
Ali Graham's Avatar
How are you guys correcting the balance of your cars? Of course it isn't as easy as sticking some lead down where the missing cell is as you will be way over weight!!! Is the easiest way just to move the receiver over to the right of the chassis in front of the cells?
Old 01-05-2007, 12:39 PM
  #444
ttso's Avatar
I don't think you need to move anything as 5 4300mAh cells is heavy enough to counter motor+ESC+RX+servo, UNLESS you using some crazy heavy device.
My TA05 balanced well with 5cells EP4300, no fan no heatsink. Nice! (with 6cells, I need to add at least 30g on ESC side, and it still not balanced well)
ttso is offline
Old 01-05-2007, 01:18 PM
  #445
HappyHippo's Avatar
Let me guess his name is S.... G.......
Old 01-08-2007, 05:01 AM
  #446
Ive heard from several people something you might think of some kind of paradox: with 5 cells the motor and speedo gets warmer than with 6 cells. My inital testing have also shown some indications on this (GM-BL).
This cant be good for anyone...
Old 01-08-2007, 06:19 AM
  #447
Thats weird...
I noticed the GM BL specs says its operated voltage is 7.2 - xx.
Maybe this has something to do with it?
Itchy is offline
Old 01-08-2007, 06:32 AM
  #448
ttso's Avatar
This cant be right. Both ESC and motor are cooler in 5cells than 6cells. The only thing that might get a bit hotter is battery.
ttso is offline
Old 01-08-2007, 06:49 AM
  #449
Could be a GM-related problem. But their Genius 70 is also specified 7.2-xxx but it works fine in 1:12....even without Rx-battery.
Old 01-08-2007, 07:07 AM
  #450
HappyHippo's Avatar
No heat to mention here, actualy it the batterys that are geting hot
