EFRA decision. 5 cells -1350gr
#241
Originally Posted by CAi
I think most of us know this already...
The point is to have fun and have speed and have power and have fun.
Are the cars really suffering of extra Power?
Brushless motors with sintered rotors stand the "extra" power just fine.
If looking the videos from Yatabe..its not looking fun, its looking slow
Opinions of these things will always differ though...
So typical Swedish way to thing about others
I'd say one could argue that you actually confirm the correctness of this statement with that post!?
People are not as stupid as you think. They are even much more stupid.
#242
I think allways hobbyist best.
Personally i like 6 cell. It is clearly coming thru...
With 6 cell everybody had enough power etc.... to compete with the top. It was all in your own hands (setup + driving).
But.. Thanks anyway "Kentech"
Ps. This is racing to find who is fastets. Not who has softest lines and who is saving energy most and not dumping... (just my thoughs).
#243
Originally Posted by John Doucakis
The above google link is the 6 cell 8 minute JMRCA finals from 2005. If you watched the whole video and pay attention to the timer on the lower right corner you would realise it is 8 minutes.
These links are short clips from the 5 min. 4 cell JMRCA finals of 2006
Masami:
http://www13.ocn.ne.jp/~mirage-j/gal...pB/06exp02.wmv
Hara:
http://www13.ocn.ne.jp/~mirage-j/gal...xp/06exp01.wmv
Both occasions aren't fast enough I think..
Next time try to post more accurately.
Masami:
Hara:
#244
Originally Posted by *SBH*
Hi Bob
Please be aware of one very important thing in this case.
These rule changes are not made because the cars are going to fast, but only because the sport have problems with motors, and speedos overheating and blowing up. Everyone have to use fans and other cooling acessories to keep the equipment working for only 5 minutes.
This might not be the best or ultimative solution, but it works for now and will probably buy some time, untill we find the golden solution of them all.
Lets all try this and see if its really so bad. - And then think positive towards the future, and try to find the prober solution.
Sincerely
Søren Boy Holst
Sincerely
Søren Boy Holst
Also, perhaps it's finally time to simply make the races a bit longer. If you have to make a longer run time, you have the same amount of power to use, but need to use if over a longer period of time. This means a lower average heat (just over a longer period of time), less wear, slightly easier to drive. I feel if we had races that were a minute or two longer in time, then racing would be a better value too. That concept has already been well debated here in these forums and doesn't need a re-hash here, but it's part of the equation.
But to put it simply, would you rather get 15 minutes of track time on raceday, or 30 minutes? More bang for the buck with longer run times.
I don't know that the batteries, or the number of cells are the problem we are actually seeing.
...but only because the sport have problems with motors, and speedos overheating and blowing up....
Mind you, they are my personal thoughts. Doesn't make them right or wrong.
#245
in most other forms of racing, its not about all out speed except drag racing. The fuel consumption, tire wear and what not are all factored into each drivers approach. I also think that is fun.
I recently competed in a 24 hour enduro (for the Guiness world record) My team won, and it wasn't because we had the "fastest" car on the track, although it pretty much was. But we did some things to win, like turning down the EPA on the throttle to 85%. This saved the batteries, and the tires, and helped us spend less time in the pit, cause we had a slower pit than most of the other teams. We didn't drive for the fast lap, we drove to win the race. And it was alot of fun!!
This isn't necessarily the case with 5 minute racing, but I remember back to barely making run-time in stock offroad with 1700's. It was alot of fun too, to set your game plan and try to limit yourself with the throttle and drive smooth lines so you could save some battery for the end. I think that helped make better drivers too.
#246
Another quick thought.
This will not save anybody any money, and will cost you... sooner or later. For the sake of debate, let's just say that 5 cell racing is the hot ticket. The majority of every vehicle has been designed around 6 cell, from the electronics to the chassis.
Make no mistake, if 5 cell is the rule, you will see new vehicles (LOT'S OF THEM, it's the manufacturers role in our industry to react and supply what the racers want and need). All these new cars will be specifically made for that rule. A whole new amount of engineering can be done with the space saved from that missing cell, and the car will probably be better, it's just evolution. Same with electronics, you will need to re-purchase those too.
Do you think the manufacturers could make an even better race car if they all of a sudden had another 2 square inches available on the chassis? Yep.
#247
Bob - Manufacturers will come out with new chassis annually whether we run 4,5,or 6 cells. This is driven by the market. Hobbyists get bored and want a change every 10-12 months.
We have been thermalling speedo before Brushless. I saw it happen at the 2003 ROAR Nats in NC. The reason was the brushes we were running in Mod then. They had reached their limits. A month later we started running the CS Silver, Reedy Plutonium and Trinity XXX brushes. This bought us time until today where the cells have gotten to the point where nothing works. The better a driver you are the more motor problems you have since you are working your gear harder.
This is all Mod racing of course. Most of the guys here run Stock and 19T and do not have these problems.
#248
I was at a club race this weekend, and 6 of the cars in the rookie class were XXXS's..... most were Losi RTR's that these folks picked up and were club racing with stick packs. And I say, "bravo for them!!"
Where would a 5 cell rule leave these people if it became a universal thing? None of them had any troubles with motors or batteries. And any car with all the cells down one side isn't exactly going to be easy to re-balance.
Not everybody is running a new car. Were do we leave the 80% that are left?
I feel the problem is accurate as you described it, The batteries are better than some of the motors and controllers. But to solve the problem by fixing the part of the equation that already works "the batteries" doesn't really fix the problem. The problem is motors and speedos, the majority of the problems are brushless, and manufacturers are working on it. Nobody wants to be known as the speedo that can't finish a race.
Just seems as though the wrong thing is being addressed with this solution.
#249
Originally Posted by kentech
There's no need for unlimited power to have fun.
You can officially have WAY more motor than you can ever use, and the batteries to make time with it. And pretty dang cheaply.
Anybody that has ever hand pushed a car down a straightaway to set the trim knows what I'm talking about.
#250
The among of Stupid changes in EP is already killing the sport. I see more and more migration to GP.
What we need is more robust Motor and ESC + longer run time.
All these decision is way too commerical - Hell Bull Shit!
This is going to help the EP Industry Short Term, longer term it's dead end.
Too much Speed? Why don't u build wider and longer track?
U have too much money does that mean u need to burnt or dump it away? And what quantify "too much" power and speed? U ever hand out with the 1/8GP guys?
#251
Anyway, by building longer & bigger tracks mean that the track owners would have to cough out more $$$ to buy land and more building materials to lay on the extra land.In some countries where land in a premium
In 1/8 racing, in the pass 1/8 on road have no need for a air restrictor,but for the last IFMAR championships an air restrictor is used to reduce power & speed of the cars. Nitro drivers have different size venturi to limit power delivery,which in some case makes the car easier to drive and better lap times...
Anyway,why not everyone just hang along the ride of change. It see where we end up 3-4 yrs from now...
#252
I just returned to touring cars after a 2 year layoff...seems to be the same...constant change
Bought a new '06 Masami BD Yoke, couple of new chargers, foam tires etc. Now have to purchase 4200 cells...WOW, can't believe we are up to 4200's. was hoping to be able to practice with old 3000's and 3300's to get up to speed again...might not be racin' for a while. Still gotta love this hobby/addiction LOL
#253
Welcome back....You've rejoin during a time of big changes to the sport.
#254
I dont think any switch to 5 cell will happen anytime soon in the US. I visited and plan to race at Josh Cyruls CEFX raceway the past weekend and most of my old racing buddies were running the same brushed motors, etc. 19 turn class seemed to have a good turnout. I do agree with Bob that if it catches on it will breed a whole slew of "hop-ups" for lack of a better word...maybe "revisions" would be better...chassis etc. I was really expecting to see more brushless setups after such a long layoff and was pleasantly surprised. The runtimes of our current setups amazes me! Maybe i am just getting old LOL...I remember being excited when 1700's hit the scene. I hope dont get discouraged and go to 1/12 scale.
#255
Inside, they are closer to 4900 already....
That´s, our problem.
