Old 11-04-2006, 09:10 AM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default glueing graphite?
is there a type of glue that will be safe to use on a carbon fiber or graphite chassis? i have both and im making some new parts to help center the gravity and weight better. but i want to glue some parts together, and dont know what type is safe to use
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 11-04-2006, 03:17 PM   #2
Iceracer's Avatar
cyanoacrylate (CA) glues are certainly safe to use on graphite and carbon fibre. Since most glues rely upon mechanical adhesion, a roughing of the surface will improve the mechanical bite. Maximizing surface area on the joint will also increase the strength, as well a placing the joint in a stress in a sheer, rather than tension.
Iceracer is offline   Reply With Quote
Old 11-04-2006, 03:20 PM   #3
vabroom's Avatar
I have used CA in the past with great success. You need to be quick in putting the pieces together and probably put the pieces in a vise to squeeze out the excess glue and to keep the pieces uniform in thickness. I've heard epoxy works well and is slower in curing, but haven't tried it.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 11-04-2006, 08:02 PM   #4
thanks. im bout to get some more CA anyways cause i need to mount some new tires. the only epoxy i have is for steal and hard plastic like gas tanks on a dirtbike. i only use it on full sized things with engines since it is so strong though.
Old 11-04-2006, 11:18 PM   #5
Just be careful.... with some composites CA reacts and emits a "smoke" which is very TOXIC!!!!! Do not breath these fumes.
duckman996 is offline   Reply With Quote
Old 11-05-2006, 11:18 AM   #6
haha. yeah i know. im just worried about it screwing my chassis.
Old 11-05-2006, 02:05 PM   #7
do yall know if gorilla glue would mess up graphite? i use it on basically everything, but im not sure if that would mess up graphite.
Old 11-07-2006, 12:57 PM   #8
MrBlack's Avatar
Just a note epoxy is what is used to glue the graphite to gether originally however if you use a glue that is stronger then the epoxy to glue it together and the force applied to one piece is great enough you can basically force one of the grphite pieces to de-laminate. I would suggest screwing the pieces together with Ti buts and bolt if possble as it provide a better stronger junction since the graphite has already been epoxied and cured prior.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Tyre Glueing LogiK Nitro Off-Road 3 05-02-2008 07:33 AM
Glueing Tires Bigmaxy Rookie Zone 3 08-25-2006 01:59 PM
Super glueing tires beer_ninja Rookie Zone 2 09-26-2005 04:48 AM
Glueing Tires RoadRat Electric On-Road 9 07-23-2003 11:38 PM
Glueing tires on wheels.....Help!! GKHTC3 Electric On-Road 6 11-15-2002 10:52 AM
