Ooey, gooey, sticky foam tires.
One of the tires i trued today isn't like cutting down the tire. It's more like melting the tire, leaving it ooey, gooey and sticky. What can cause this to happen?
umm I'm not sure what you mean by compund, but it was speedmind 45sh, I was cutting it down fairly quickly, and It had around 20 runs on them.
>_>
<_<
Another tire I "trued" wasn't sticky. And the tire that is gooey, is only gooey when its hot. when it's cold, its sticky.
<_<
Traction compound
What traction compound were you using? were you using tc on only one tire/ or different tc's on different tires, I had a problem somewhat like this using trinity's red dot on dirt oval foams.
I used Paragon Ground effects on all 4 tires.
