Old 02-21-2003, 04:27 PM   #61
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
So I guess that the Hudy system isn't measuring droop? Or it's just using a different system.
Forgive me, but I've gotten my definition from the book Race Care Vechicle Dynamics (Milliken & Milliken) and, although I believe I understood what they were talking about, I very easily could be confused about it. That was why I used those definitions.
So, if that's not correct, then why does Hudy, Integy, AE, Losi, etc. include a tool that measures the travel from the plane of the bottom of the chassis?
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-21-2003, 05:11 PM   #62
Boomer's Avatar
Originally posted by BigDogRacing
Sorry Boomer, but you are wrong. If you had read my prior post, you would have saved yourself a lot of typing.
BTW, I did read your prior post. I never mind typing. It doesn't take me long. . .
Old 02-21-2003, 07:42 PM   #63
Iso Octane's Avatar
So by those gauges, the smaller the number, the more downtravel there is?
The thing with that way of measuring is that (and this is strictly imo) each measurement is only good for that particular set up. For example in that pic of "3mm". Depending on chassis design "3mm" could mean more or less actual downtravel. Furthermore, suppose that in that pic, the position of the suspension arms right there is exactly the same position they are in at static ride height... what then? (I would say 0 droop) And then suppose you change the ride height so that the chassis rides lower, you'll still be measuring 3mm, but the downtravel has changed.
If I have some concepts totally wrong, I apologize.
Iso Octane is offline   Reply With Quote
Old 02-21-2003, 08:21 PM   #64
Thumbs down tweak/droop/camber/ridehite/bumpsteer...
Hey Dudes,
All I got to say after 14 years of racing is put [email protected]#$%^&* down ON the track and race it!!SHEESH!!??
bigd4343 is offline   Reply With Quote
Old 02-21-2003, 08:25 PM   #65
Default settings...
If you want to know what yur setting the droop/ridehite/camber etc. does then make one change at-a-time and run your car...clocking yur laptimes and see if it improves yur speed.
NUFF SAID!!
Old 02-21-2003, 09:36 PM   #66
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Big D- now that sounds like a good idea... I think I'll do that. How about a solid week of tuning and racing at the biggest r/c race in history!!!! No, wait...... I already did that 2 weeks ago..... dangit!!!
Happy racing!!!
BigDogRacing is offline   Reply With Quote
Old 02-22-2003, 09:28 AM   #67
Default 2 weeks ago?
Happy racing!!!
As in the infamous snowbirds?...was that "you" I saw making the top racers nervous?lol
Old 02-22-2003, 11:04 AM   #68
Default HEY DUDES,
I haven't been able to find any stock or modified settups for my tc3 for running concrete tracks...anyone got any ideas or??
Old 02-22-2003, 09:43 PM   #69
popsracer's Avatar
Default settups for my tc3 for running concrete tracks
bigd4343;
Start with Take-Off 27CS tires and a medium insert. These work GREAT on concrete and wear good too.
Pro-line S3's work good on concrete, wear very poor.
Losi "REDS" work good on concrete, wear is ok as long as it is below 80F. Hotter temps tear them up.
popsracer is offline   Reply With Quote
Old 02-23-2003, 07:35 AM   #70
Default Re: 2 weeks ago?
Yea, I snuck in the A main in 19 turn Sportsman- prolly just lucky.... but I had a blast!!! Dude, you can not imagine how much traction that track had!!!!!
Old 02-23-2003, 03:04 PM   #71
Default TC3 & traction!
Hey Dudes!,
popsracer....stock or mod? gearing?snowbirds traction? I thot I was on a rr track!!
Old 02-24-2003, 09:19 PM   #72
Trader Rating: 17 (100%+)
Guys, I must say I tried big dogs idea of tweaking the car and so did my friends and agreed we like that method. the car shifted the same in every corner and drove straight coming out of corners and on the straight away.
429racer is offline   Reply With Quote
Old 02-26-2003, 11:38 AM   #73
Maybe this is a dumb question. I drive a XXX-S and with battery installed, especially GP3300, my car is quite heavy on right side. If I set ride height equal all the way around and then put it on the MIP tweak station, my tweak is WAY off. If I adjust collars to level tweak, my static ride height is very different right to left.
Any thoughts?
timc is offline   Reply With Quote
Old 02-26-2003, 11:54 AM   #74
Try adding collers one side and removing them from the other by the same amount.
That should keep the chassis level, then re check your ride height.
HTH
Mort is offline   Reply With Quote
Old 02-26-2003, 12:07 PM   #75
That's what I did. Now the car is perfect on the tweak station but off the station my ride height is way off side to side.
scales for tweaking? J&L Johnson Electric On-Road 23 01-24-2007 06:37 AM
When tweaking a car... K_King Electric Off-Road 10 01-19-2007 12:38 AM
Need some online articles regarding Pro 4 type chassis on the TWEAKING issue... Solara Electric On-Road 1 01-03-2005 12:39 PM
[help] want to buy tweaking tool set aoizip Electric On-Road 8 08-22-2004 12:43 AM
shoe type clutch tweaking sup Nitro On-Road 16 11-04-2003 08:48 AM
