shock shaft pliers? >
shock shaft pliers?
Like Tree2Likes
shock shaft pliers?
Old 10-31-2006, 12:27 PM
gonzo416's Avatar
Trader Rating: 39 (98%+)
Default shock shaft pliers?
where can i get some shock shaft pliers besides team tamale because they are out of stock?
gonzo416 is offline
Old 10-31-2006, 12:30 PM
Trader Rating: 32 (100%+)
Integy makes a nice set - http://integy.automated-shops.com/cg...08106299543.64
A. Rhodes is offline
Old 10-31-2006, 01:04 PM
XrayFK's Avatar
Originally Posted by A. Rhodes
+1
http://www2.towerhobbies.com/cgi-bin...?&I=LXKTR1&P=7
XrayFK is offline
Old 10-31-2006, 01:09 PM
1fastdude's Avatar
Trader Rating: 16 (100%+)
Tamiya also has a nice set too. They have plastic jaws.
1fastdude is offline
Old 10-31-2006, 01:11 PM
theisgroup's Avatar
team tamale is in the process of making some. we just bugged larry this weekend that we all need some. so they should have some soon. just shoot larry an email
theisgroup is offline
Old 10-31-2006, 01:12 PM
Mr. Shookie's Avatar
Yea tamiya's are way pimp...
http://www.hobbylinc.com/htm/tam/tam74065.htm
They are a bit more expencive...
But man they a can be used for many other things too though...Like those stupid nylon nuts that hold the wings on and you scratch the paint.....
-Shookie <><
Mr. Shookie is offline
Old 10-31-2006, 08:41 PM
hierog's Avatar
i'll have to go with the Tamiya ones too, just cause they are Tamiya! i do like the Integy ones too though because of the indentions to hold the shaft
vic
hierog is offline
Old 10-31-2006, 11:00 PM
olhipster1's Avatar
Trader Rating: 102 (100%+)
Default Team Tamale
go with the Team Tamale ones...all of their stuff is absolutely top quality...I believe he has a pic on his web page.. www.TeamTamale.com
he has a reputation for only making the best stuff.
Wish he would make a complete tool set.
olhipster1 is offline
Old 10-31-2006, 11:39 PM
SpeedTech's Avatar
Been using the Integy Pliers works great from touring car shock shafts to 1/8th buggy shock shafts.
Steve Wang
SpeedTech is offline
Old 11-01-2006, 01:53 AM
Hope can help you.
http://www.racing11.net/shop/product...oducts_id=2186
initialrays is offline
Old 11-01-2006, 01:54 AM
Frank McKinney's Avatar
Do people really have a problem scratching their shock shafts? I used a cheap pair of vise lock pliers with almost no problem for years...
Frank McKinney is offline
Old 11-01-2006, 09:58 AM
R/C Tech Elite Member
JayL's Avatar
yes they can scratch, esp some of the ti nitride coated ones.
I own both the integy and the Tamiya
I use the Tamiya 9 times out of ten as they are sure not to scratch, but some times a cup is alittle too tight to get on all they way and I resort to the integy as it has alittle better grip.
Haven't had a scratch with either
JayL is offline
Old 11-01-2006, 04:04 PM
Trader Rating: 44 (100%+)
what's wrong with putting fuel tubes around ur existing pliers?
wouldn't that achieve the same purpose?
wyl03 is offline
Old 11-01-2006, 04:16 PM
gonzo416's Avatar
have you tried this? i think the electrical shrink tubing would work over needle nose lock pliers, or a piece over the shock shaft then cut it off once built. i'm gonna give it a try tomorrow on the T2 007.
gonzo416 is offline
Old 11-01-2006, 05:22 PM
ASM
ASM's Avatar
Trader Rating: 30 (100%+)
Using large wire cutters, hold onto the shaft in the very first (top) thread and it'll work awesome. Of course, it can't cut into the shaft yet will not let the shaft slip or spin. You end with no chances of maring up the shaft when you hold in the groove of a thread. Didn't believe it myslef but it's worked great for years....and it's free!
Nerobro likes this.
ASM is offline
