shock shaft pliers?
#16
Originally Posted by ASM
Using large wire cutters, hold onto the shaft in the very first (top) thread and it'll work awesome. Of course, it can't cut into the shaft yet will not let the shaft slip or spin. You end with no chances of maring up the shaft when you hold in the groove of a thread. Didn't believe it myslef but it's worked great for years....and it's free!
#20
Yep, forgot about using wire cutters on the thread part.
Hmmm...wire cutters already in pit box, or $20 pair of 'shock pliers' - no contest
#21
1. Get a piece of paper
2. fold it 3 or 4 times
3. wrap around shock shaft
4. use needlenose or regular pliers
common tools, a piece of paper (maybe an old setup sheet)
cheapo!
cheapo!
#22
i just use a pair of "dikes" (side cutters) and hold the shaft on the threads, theres always one or two showing.
#23
I always used the dikes as well, works great, get a dull pair though as I actually cut a rc18t shock shaft..
It's fun to for me to have 'the' tool for the job, you should see the crazy tools I have
...although it was fun to pretend I was McGuyver, lol
#24
Originally Posted by gonzo416
have you tried this? i think the electrical shrink tubing would work over needle nose lock pliers, or a piece over the shock shaft then cut it off once built. i'm gonna give it a try tomorrow on the T2 007.
the only concern i would have about clamping on the thread (when using wire cutters, etc ..) is the risk of damage to the thread.
#25
Originally Posted by wyl03
yes, i have tried this.
#26
