Old 10-31-2006, 10:39 AM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default Parquet flooring, running sedans on this?
We are looking for a place to run sedans and other vehicles like rc18s this winter, and one that was located has parquet flooring. Has anyone run on this before? If so I have a few questions:
1. What type of tires work well on this for sedans?
2. How durable is it to getting tire marks with people using at most 19 turn power?
3. How easy is it to clean tire marks off of?
Thanks for any advice you have for running on this surface.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-31-2006, 10:43 AM   #2
Victor Vector's Avatar
Is North Dacota in England or sumfink ??
VV
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 10-31-2006, 10:46 AM   #3
Tech Legend
Cain's Avatar
Its in the good ol USA, but since the up front cost of carpet may be prohibitive, I am trying to see if the surface can handle racing. if it can, for this year if carpet can't be had it can be ran on as it sits.
So if anyone regardless of location has tips on running on this surface please feel free to post.
Old 10-31-2006, 11:34 AM   #4
sosidge's Avatar
Sounds similar to the "slippy floor" surfaces a lot of us run on here in the UK, either gym floors or older wooden floors.
Generally not much grip, slick/treaded tyres are useless, but we use Schumacher SST Minipins which make the surface entirely raceable.
I can go into more detail on part numbers and tyre setup if you want.
I've never seen tyre marks as an issue with tourers. Buggies with mod motors can lay down thick lines of rubber though if you do a donut.
Old 10-31-2006, 11:35 AM   #5
VV
UK, not England.... grrrr...
Parquet (wood block) flooring, if it is polished and sealed, Schumacher mini-pins are the way to go, but wear central, if it unsealed and un-polished, then you can run slicks (but don't use additive), or a realy old skool trick is foams coating in silicone.
DA_cookie_monst is offline   Reply With Quote
Old 10-31-2006, 01:19 PM   #6
Tech Legend
Cain's Avatar
I'll find out for sure tomorrow then, swing by there to see the room if its open.
Old 10-31-2006, 06:41 PM   #7
Default silicone on foam
This is very good for traction--however the next group to use
the floor will find it is very slick--say a lot of problems when we
used a roller rink with silicon treated tires--the rains tread worked
very well.
SrRC is offline   Reply With Quote
Old 10-31-2006, 07:13 PM   #8
G Ace's Avatar
Send a message via AIM to G Ace Send a message via Yahoo to G Ace
I have run my 18T with Losi street tread tires on it in the gym where I work. The traction seemed ok until the tires built up some dust on the surface, then it was terrible. It seems like if you were to mop the floor before running on it and clean the tires with motor spray before or after each run, it might work. If the track surface stays clean, it seems like really soft compound rubber slicks would work (Pit Shimizu, HPI or Take Off 20's or 22's, etc.), but I have never tested this out. HPI or Schumacher treaded tires might work also. If I get a chance I will try them and let you know.
One thing I do know.... I tried running my 12th scale car with foam tires on the gym floor, and it was impossible to even run a straight line with a stock motor. The car just instantly does a donut no matter how little throttle I used.
G Ace is offline   Reply With Quote
Old 10-31-2006, 08:22 PM   #9
chicagokenji's Avatar
Default gym floor
we've raced on a middle school gym floor a few times. Smooth slick floor. The only tire that worked was the HPI Advan A038 tire with no insert whatsoever, but did use tire compound. The regular racers there through the years tried over 15 different types of tires and the Advan without inserts was the only thing that hooked up. The floor was always damp mopped previous to racing to get the surface dust off.
It might be worth giving them a try.
chicagokenji is offline   Reply With Quote
Old 10-31-2006, 08:28 PM   #10
Z
http://rctech.net/forum/showthread.php?t=134939
www.heartofamericaseries.com
2007 RC Pro Series National Champion - Expert Sedan
2005 ROAR Region 8 Nitro Sedan Champion
Stay Thirsty My Friends
Z is offline   Reply With Quote
Old 11-01-2006, 07:48 AM   #11
G Ace's Avatar
Originally Posted by Z
Spending $800 on used FastTrack carpet would be a much wiser investment than spending $800 (or more) on mops, buckets and rubber tires that might not work.
Old 11-01-2006, 08:31 AM   #12
Default hmmm
If you had a place to race but it was a temporary track that needed to be taken up after each race day, how do you get 36x75 feet of ozite to lay flat every time you set up the track? Not to mention the 36 foot wide section is three pieces 12 feet wide.
Every ozite track I've raced on the rug is heavily stretched and glued to the floor, not just rolled out.
Old 11-01-2006, 08:37 AM   #13
RaceAce701's Avatar
Trader Rating: 86 (99%+)
a good quality indoor outdoor carpet is just as good a ozite and is alot more durable
we raced on one carper got 10 years with no trouble it has alot of grip also
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 11-01-2006, 09:01 AM   #14
Trader Rating: 28 (100%+)
Its totally possible.Not all carpet is glued.Last years Carpet nats track is a perfect example of a track thats not glued down. Can be done.
I agree,$800 on 3 rolls of 75 feet in good condition is a good deal!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 11-01-2006, 10:01 AM   #15
TRF415boy's Avatar
Schumacher Rally Blocks yellow compound is what you want
TRF415boy is offline   Reply With Quote
(((((((2-OFNA CD3 SEDANS)))))) mlt138 R/C Items: For Sale/Trade 3 01-02-2007 09:43 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
WTB or WTT looking for new in box electric sedans fasthpir40 R/C Items: Wanted to Buy 2 04-11-2005 10:45 AM
WANTED xxx-s sedans shrekair R/C Items: Wanted to Buy 16 06-14-2002 02:22 AM
