The Official 4300 Brushless/LiPo/Foam Touring Thread >
Old 12-29-2006, 09:51 PM
  #226
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Is it thermaling from temp? And what temp?
Is it possible that the speed control is the problem?
Was it temped? Bizzare.
UN4RACING is offline
Old 12-29-2006, 09:58 PM
  #227
UN4RACING's Avatar
Rugdog a racer at our track was able to do one. I'm not sure what brand or enen if it was 4800? But it didnt have a case, and it was shrink wrapped.the wire connection was coming out by the rear diff, with a deans plug.
Sorry no picture but any things possible.
Old 12-30-2006, 07:26 AM
  #228
Customworksking's Avatar
Trader Rating: 74 (100%+)
Default wonder
Hello all What is a good temp to run a novak 13.5 with GTB esc and IB4200 batt do I want to run it like my co27 140 to 150 ?
Customworksking is offline
Old 12-30-2006, 08:00 AM
  #229
UN4RACING's Avatar
A safe range is 150 to 170. But 120 to 130 seems good on our track size.
120 seems to be really good. I think Chalie hit it pretty good, with the sintered rotor its hard to get it real hot even if over geared ,the track size is the factor. I havent hit over about 135 with my 4300 with a sintered rotor.
He mentioned the stater is getting hotter than the rotor. Be carefull if you hit 150 with a sintered rotor your probably over working the can.
And goodbye effiicency
Old 12-30-2006, 08:38 AM
  #230
StewartFan20's Avatar
Originally Posted by rugdog
anybody figure out how to shoe horn an orion platinum 4800 brick in a losi jrxs
if not what kind of lipo can I wedge in there
Max Amps 4000's will fit. You just need to remove the shrink wrap, reroute the wire to come out the top instead of the side and then re-shrinkrap it.
StewartFan20 is offline
Old 12-30-2006, 04:53 PM
  #231
ok thanks I ran it today I been running it 125 to 135 took it up to 150 today and it didn't change lap times were the same so I got it back down to 130
Old 12-30-2006, 08:08 PM
  #232
UN4RACING's Avatar
I havent been able to get mine that hot. I guess I dont have enough room for the teeth. And I think you have seen our track.
My best runs where at 120 to 130.
And honestly I have tried to abuse these motors.
Not my lipo's though.
To bad we cant compare side by side at the track.
Old 12-30-2006, 08:13 PM
  #233
UN4RACING's Avatar
At 150 did it seem slugish, sounds like it didnt hurt a thing if laps didnt change what about battery voltage did it drain more?
Old 12-30-2006, 11:01 PM
  #234
Default car
well I ran 34 laps and the 26th was my fast lap I run IB4200's didn't check the bat for dis charge time but thinking @ the 26th it can't be much diff ..I run a kyosho stallion 100 spur and @ 150 33 pinion 31/100 is 128 deg....
Old 12-31-2006, 02:03 AM
  #235
UN4RACING's Avatar
I'm running the 4300 with foams, and 4800 lipos, the consistancy of the lipos can some times hide the fade of being over geared. Are you running rubber I thought maybe that is the temp differance.I noticed 2 teeth to be 20 degrees hotter. I have noticed about 4 degrees per tooth on my motor.
Looks like yours took 10 degree jump per tooth.
Old 12-31-2006, 09:53 AM
  #236
Default lipo
yah I run low bite rubber so the motor has to work more than high bite I will see how it is at the novak/high bite!
Old 12-31-2006, 04:50 PM
  #237
UN4RACING's Avatar
Good luck at the novak, shake Mr. Novaks hand for racer X.
I would custom set the speedo for smoother bttom end if the tracktion is real high. That will keep the temp down and improve efficency.
Old 12-31-2006, 04:56 PM
  #238
Cool esc
I Will look at the book and see what profile's apply
Old 12-31-2006, 05:29 PM
  #239
HarshGuy's Avatar
Originally Posted by Bob Novak
As far as the coil wire measurement I think Charlie answered that and we will be posting the inductance readings on our website.
Bob Novak
2 questions regarding this info on your website:
1) Will the measurements stay as posted regardless of rotors (e.g. a 4300 upgraded to a sintered rotor)
2) Can the motor be left in the car (e.g. if a 'post tech' was to be done of top 3 cars)
I'm assuming the answers to both is yes ...but don't like a assume
HarshGuy is offline
Old 12-31-2006, 05:51 PM
  #240
UN4RACING's Avatar
Hey custom I found less grunt coming out of the turns seemed faster, or smoother deffinitly helps the diff. I think the drive freq would be around 6 or 7. I 'll check to.
