The Official 4300 Brushless/LiPo/Foam Touring Thread >
Old 12-06-2006, 03:01 PM
  #211
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Heres my answer. With the sintered rotor The heat range is about 3 or 4 teeth. The higher ratio is the problem in performance and not the temp.Due only to the size of the track. Am I close or am I not making any sense. This is a delima syndrome and I are trying to figure out. In other words take the inefficiant ratio to a bigger track and now the efficancy is back. In other words over gearing is'nt only determained by the temp. And the sintered rotor seems to be the clue? In an earlier post you mention the load power. And how it actually cools as well as the gap.? We just want to know where the fade is. I believe over gearing.Thanks to Mr. Black we have ruled out the voltage. That sintered rotor is the bomb, and It is fast regardless. Just trying to catch a ghost.
UN4RACING is offline
Old 12-06-2006, 05:41 PM
  #212
Charlie's Avatar
It is a balancing act for sure.
I think the smaller the track is, the lower your max temp will end up being. I think youre right though, you can get to a point that it doesn't get faster, just "bogs" so to speak.
I've been learning that overall, it seems the 13.5 max range is around 120-150 depending on conditions.
Figuring out what size track needs what gear is the next step, but we've learned already, we're not going to give out a fixed gearing recomendation, just fine tune our temp recomendations.
With the sintered rotor you're actually experiencing the effects of the stator/coils getting hot, and the lack of power from the motor to pull the gear over the course of the run. It's masking the problem slightly I suppose.
YOu can always email us directly if you get antzy..... Sometimes I can't get to the internet before I leave. But emails are done first and foremost around here.
Charlie is offline
Old 12-06-2006, 05:51 PM
  #213
UN4RACING's Avatar
I swear if it where a snake. That is the answer thank you. that sintered rotor is a miracle in a can. Thanks, these questions we save for everyone it's good reading. I'll say you are a pretty good ghost buster if you caught my edit to my answer. Thanks you have come threw again.
I was editing to make it more understandable and you were posting. Now thats service. Your good.
...................X....................
Old 12-06-2006, 09:48 PM
  #214
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by UN4RACING
Is noone out there. I'm going to hit auto submit And get this baby back up front if I have to. I need something to read Guy's
Just so everyone know's Syndrome's GQ's are fixing to get a solid 3 weeks and at race pace. I stuck With the parma's, and there was absolutly no variance in performance. He was fast.My parma's are getting 2 TO 2.5 weeks.
Money's on the GQ's. Later.
I'm going to go read myself somemore.
Has anyone run plaid purples recently to get a bit more wear from foams? I know they'd be slower but if everyone in a particular class aggreed to run only plaid purples it might make for a little savings on your tire bill if they don't wear as aggressively as pink double pink. I am assuming one could compensate for some of the reduction in grip with set up.
andrewdoherty is offline
Old 12-06-2006, 09:53 PM
  #215
syndr0me's Avatar
Trader Rating: 32 (100%+)
We haven't tried that yet, but it's definitely worth a go.
syndr0me is offline
Old 12-06-2006, 10:05 PM
  #216
Chris Adams's Avatar
Plaids and purples work fairly well... I used them early last winter when I was too poor to afford the soft stuff...
Chris Adams is offline
Old 12-06-2006, 10:07 PM
  #217
I'm planning on riding out the rubber tires train here at my track. But please post if you get to try it. Were (Or maybe its just me) mostly looking at ways to cut our tire bill.
You gotta read this though. I posted it on our local track forum and thought you all might be encouraged with some positive support at our track
I just watched a so so racing buddy take a XXX-S RTR with the brushed motor straight from the box out onto our carpet track and post consistant 17.4-17.9 second laps (we have been experimenting with a BL 4300 LiPo class with CS27 rubber tires and have just now dipped into the 14's with most of our laps in the mid 15's) Thats with the treaded RTR ruber tires, questionable set up (I saw one of the 4 rtr's our track/store owner bought for spectators to race for free with positive rear camber on one rear tire) no body, and a house transponder zip tied up high on the chassis. The motor was noticabley slower than a stock motor, and he was running an 1800 stick pack. Plus I know he was driving a bit conservatively becasue the car wasn't his. He could have gone a bit tighter and gained five tenths easy. I can't wait to get these cars into the hands of some spectators just to watch them have a blast for free. My buddy was driving with the throttle at 100%, but I know spectators will have FUN with them even if we turned it down to 50% so they didn't break as many parts. I really couldn't believe just how well that car hooked up with those RTR treaded tires. Makes me wonder what I am doing wrong! If he drove that car clean in our last rubber tire BL class race he could have been right there with us!!!
Old 12-07-2006, 08:26 AM
  #218
UN4RACING's Avatar
I'll volenteer To do some plaids and purples, I'll pick some up to day I'll start them at 60mm.Point season's over anyway. I'll run them tues, we have a big race this weekend and the groove should be established. Till then. Later.
Old 12-07-2006, 09:26 AM
  #219
padailey's Avatar
Well since we just had our enduro in Omaha, guys had switched to running a little harder compounds to save on wear and they seem to be working fine. I don't know exactly where these fit in the conversation of soft vs. hard but here's what I've tried. The Magenta - Red/Magenta from GQ which I think are pretty close to Purple/Plaid are working very well... but the Gray- Gray/Black are not doing very well. The Gray combo made my car push really bad and others have found they can't get the rear to stick.
padailey is offline
Old 12-07-2006, 09:40 AM
  #220
syndr0me's Avatar
I'm using tan rears, and red/tan up front with a lot of success.
syndr0me is offline
Old 12-08-2006, 01:09 AM
  #221
UN4RACING's Avatar
Yah Syndromes on his way to 3.5 weeks on his. Some of that could be set up. So I guess allow for that.
The bad news is I could'nt get the parma plaids & purples some one beat me to them.Those suckers where there for over a year, and the shop is moving, I could have got them last week 30% off And I did'nt.
So I 'm going to order some spoked T&M Tires from the track. PLAIDS AND PURPLES.
Old 12-29-2006, 11:08 AM
  #222
padailey's Avatar
Default Thermal!! Grrrrr....
Ok so last Wednesday night some guys were out practicing and a buddy of mine Thermals twice with a 4300/sintered rotor. He is not running any outragous gear (several guys geared higher) but he had to switch to a spool in the front because his front diff broke. Now what is really strange is he had never had a thermal problem with the regular rotor. I guess the question in all this is does the sintered rotor degrade and become easier to overheat like the stock rotor?
padailey is offline
Old 12-29-2006, 11:23 AM
  #223
syndr0me's Avatar
I imagine it could eventually lose some strength, but those magnets are rated a like 250 degrees before they're damaged by heat. Charlie or someone might be able to give you more insight there.
Is it possible his drive train was binding up somewhere with the spool? That could easily cause the motor to run hotter. I don't know anything about spools, but are they known for being harder on a motor? Maybe you'll need to gear down when running that thing.
From what I understand, though, the temperature reached during a normal thermal shouldn't be high enough to harm the motor or a sintered rotor.
syndr0me is offline
Old 12-29-2006, 12:52 PM
  #224
padailey's Avatar
Well we were all kinda scratching our heads because he is the first to thermal a sintered rotor at our track. Binding came up but we couldn't find anything.... he actually did gear down before the 2nd thermal but obviously not enough. He should be getting his diff fixed soon so hopefully it was just the spool but it definitely is weird! Glad to hear he most likely didn't damage the motor.
padailey is offline
Old 12-29-2006, 06:52 PM
  #225
anybody figure out how to shoe horn an orion platinum 4800 brick in a losi jrxs
if not what kind of lipo can I wedge in there
rugdog is offline
