Old 10-29-2006, 05:47 AM   #1
akuhon's Avatar
Default How to reuse the old wheel
Hi all,
Do you know how to effectively remove the tires from the wheels ? I want to re-use the wheels since I have lots of on-road rubber tires, mostly sorex wheels and some nylon material wheels .....
the CA glue is very strong ...
Really thanks for the help ....
akuhon is offline   Reply With Quote
Old 10-29-2006, 06:17 AM   #2
Hi,
You can use acetone to do this (only method I know)
Remember that some wheels will completely solve in acetone, others can resist...
Proline wheels can resist and the CS preglued ones can't this I know
I use a glass bowl which I can close.
Put a few inches of Acetone in it. After put your tyres in or on top of the acetone. Than let them sit for a day or 2. The tyres will unglue and you will be able to remove them.
Be sure to close to bowl and to wear rubber gloves!!!
In case you wish to reuse the inserts remove them first... in case you want to reuse the tyres also (broken rim etc...) you may want to check every 4 hours for the glue to come loose. Sometimes the insert will vanish in the odours of the acetone...
hope this one helps
greetz
Nilezb is offline   Reply With Quote
Old 10-29-2006, 08:12 AM   #3
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
I've read that acetone works but, I also have heard that you can boil them for about 20 minutes. I haven't tried either one. I can't verify that these methods work. I've never reused any wheels. Maybe I'll try it one day, might save myself a few dollars. Good luck and let us know if it works.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 10-29-2006, 08:54 AM   #4
MK_Arbiter's Avatar
Acetone melted my tamiya wheels.
MK_Arbiter is offline   Reply With Quote
Old 10-29-2006, 09:31 AM   #5
rampal's Avatar
Send a message via MSN to rampal
just boil them for 30-45 minutes, change sides at 15-20 minutes....
take care they always have enough water... eevery wheel can resist this.... even chrome ones....
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 10-29-2006, 09:48 AM   #6
cujo's Avatar
the only wheels i've tried to reuse are my offroad wheels. I like baking them off opposed to boiling. I preheat the oven to 350, let them bake for 10-15 min., take them out and work the bead. they just pop right off. its a good idea to use a old cookie sheet and old oven mitts. my mechanic gloves were'nt quite heat resistant as i thought . but they come off easy and you don't have to worry about boiling water splashing around. after the tires are off and the wheels cool off, you can take the remaining ca off with a exacto knife. it will just flake off. hope this helps.
cujo is offline   Reply With Quote
Old 10-29-2006, 09:50 AM   #7
AM03GT's Avatar
just as some brand rims melt with acetone, some will melt in boiling water and warp...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 10-29-2006, 09:58 AM   #8
akuhon's Avatar
Thanks for the advice guys....
I did try with the Acetone... it really melted my wheels..... those Sorex and RIDE wheels. I don't think Acetone is a good choice .....
I will try some chemical substance ..... How about paint / glue remover ... any particular brand ?
Old 10-29-2006, 10:08 AM   #9
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
ask yourself this, how much $ and how much time have you invested in " attemtping to re-use a set of rims,
Now ask your self this... would you rather pay aprox $0.90 a rim..
http://www.speedtechrc.com/store/ebp...id=405&id=5126
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 10-29-2006, 12:18 PM   #10
MrUnlimited's Avatar
JasonC is right. You destroy a expensive tire to save a cheap rim.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 10-29-2006, 04:52 PM   #11
akuhon's Avatar
Sorry ... I think you miss the point.... It's not the price .... It's just because I have too many worn tires .... while the wheels still in good condition ....
That's all... That's why I'm asking....
Old 05-29-2007, 04:18 AM   #12
PeteB's Avatar
im trying to do the opposite, save a tire on a broken rim...
first time out on a new set of of tyres and a rim breaks . so really its the whole set that I cant use...
tried the hot water and the acetone, neither really did much. is there anything else that is worth trying???
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 05-29-2007, 04:55 AM   #13
VoneS3Kid's Avatar
Send a message via MSN to VoneS3Kid
Pete, to be honest i dont think this is possible, good luck. i know acitone in a can with tyres and rims in there works a treat for getting tyres off rims, stuffs tyrs but rims remain pefect.
Cheers
Team Xray/HUDY/Custom Model cars/HEI International/Fantom/Much-More/JACO/Kelletts Hobbies/Max Power/Ko Propo.
VoneS3Kid is offline   Reply With Quote
Old 05-29-2007, 07:51 PM   #14
al
Be very careful doing this. Some wheels will warp very badly in just a few minutes of boiling them. I believe it has to do with the plastic they're made of and how thin they are. I destroyed a beautiful set of Tamiya wheels trying to boil the tires off them.
quick5pnt0 is offline   Reply With Quote
Old 05-29-2007, 08:44 PM   #15
I did notice some CA brand gets brittle when heated up in hot water around 90C~100C, then tyre can easily taken off from rim, scrap the excess CA with knive and medium grade sand paper.
Once I try this method succesfully on speedmind wheels,
but beware some wheels brand don't like heated above 90C and get deform badly,
Faiz is offline   Reply With Quote
KO Propo EX-10 Helios w/ Drop wheel extension and hex wheel adaptor Justin Zorc R/C Items: For Sale/Trade 6 02-28-2007 10:32 PM
Do you reuse wheels when tires are fried? swannco Electric Off-Road 11 12-18-2006 10:11 AM
Vintage RARE Kyosho Progess 4WS (4 Wheel Wheel Steering) assoc_driver Australia For Sale/Trade 0 01-16-2006 08:34 AM
Reuse inserts for consistency JohnnyRotten Electric On-Road 6 11-03-2003 10:52 PM
·New TakeOff dish wheel VS Cross spoke wheel· ZER01 Electric On-Road 29 10-04-2003 05:14 PM
