Old 11-10-2001, 09:20 AM   #16
RacerTex's Avatar
I've had the XR3 and its a great radio and I've never had a glitch and the servos aren't as bad as the Futabe S3003. You can actually used them to race with. Once you start looking for every advantage in racing, you will need a new radio. Even though the Futaba has exponential, you really won't be able to take advantage of high speed digital servos without some servo speed control. This brings you to the realm of the KO Mars, Airtronics M8, and the Futaba 3PJ. (I don't know about the Lynx 3D).
Finally, as everyone else recommended, you need to feel comfortable with the radio. Try to hold each one for a while. Frankly, I hate the look of the Lynx 3D, but that's just me.
RacerTex is offline   Reply With Quote
Old 11-10-2001, 11:36 AM   #17
zxt
zxt's Avatar
Default What is the exponential?
Also can u list the features side by side to help me decide?
zxt is offline   Reply With Quote
Old 11-10-2001, 01:44 PM   #18
TFR
TFR's Avatar
Thumbs up
Futaba 3PDF is good.
TFR is offline   Reply With Quote
Old 11-10-2001, 03:46 PM   #19
fatdoggy's Avatar
R/C Tech Charter Subscriber
Expo's is where you can set the wheel to have not as much steering a near at the beggining and have more steering at the end. I mean like at the beggining in regards to the wheels set in neutral. You can also set it vis versa. Hope you understand cause I don't really know how to explain it. It helps so you don't overstear in a sweaper and if you have a small tight track and you need lots of steering then you can set it the other way so you automaticaly have lots of steering on tap.
fatdoggy is offline   Reply With Quote
Old 11-10-2001, 04:05 PM   #20
fatdoggy's Avatar
Towers specs.
PDF
http://www2.towerhobbies.com/cgi-bin...m?Q=1&I=LXZF33**&P=7
Lynx 3D
http://www2.towerhobbies.com/cgi-bin...m?Q=1&I=LXN491**&P=7
Horizon's Specs for the XR3
http://www.horizonhobby.com/products...Prod=JRP314127
P.S. Sorry, yes the jr servo's are better then the Fut 3003's, the jr's output 49oz/in and a .19 sec/60 degree transition time.
Old 11-12-2001, 06:16 AM   #21
zxt
zxt's Avatar
Default okay
I think I know what you are tyying to say fatdoggy...
I got the PDF today with no servos, Receiver only for $107...the guy said its only a month old. I read the manual briefly and I think I need to read it all over again. Is there really a use for the 3rd channel?
Also for those who use PDF before...whats the volt reading on the screen? I bought 8 regular AA's batts and the reading is only 10.2V...I thought it should be 12 because 1.5V x 8 = 12.
Old 11-14-2001, 08:29 PM   #22
really? it's not rare that the batts don't live up to thier full 12 volt rating, but 10.2 is pretty close to dead. I have a JR XR2 and i'm happy with it, never glitched. Anyways i after 9 volts on mine it's dead ( or at least the warning thing comes on).
So i'm guessing you got crap batteries.
Destrega is offline   Reply With Quote
Old 11-14-2001, 10:38 PM   #23
zxt
zxt's Avatar
Default Duracell 2X
I always use that batts...on my Futaba 2PCKA it works best...its about 3 hours of life...maybe 20 packs or more of batts...
The PDF warning light doesnt come off till you got 8.7volts or less...
I'll try different brand of AA's and see if it will be the same..
Old 11-15-2001, 08:15 PM   #24
TFR
TFR's Avatar
The most i got from it was like 11.5 Volts.....
those batteries are Panasonic non rechargable one....they work pretty good...
Hey man, you made a good choice on the radio.
Old 11-15-2001, 10:48 PM   #25
does any one know if the other radio manufacturers are making radios with such things as the spectra as on the 3d
was ist los? is offline   Reply With Quote
Old 11-16-2001, 12:36 AM   #26
fatdoggy's Avatar
Yes JR(R1 pcm) and Futaba(pjs pcm) but I've heard no one confirm that they can be used with the new xxtra reciever.
need a fut 3pdf rx 75 fm yeaklet4 R/C Items: Wanted to Buy 0 12-23-2006 12:15 AM
3pdf fm tc3Guru R/C Items: For Sale/Trade 0 07-16-2004 09:03 AM
3pdf SteveA R/C Items: For Sale/Trade 1 04-23-2003 12:09 PM
3pdf zoombie R/C Items: Wanted to Buy 5 01-01-2003 09:31 PM
Where can I find a new 3PDF? Morpheus2be Malaysian R/C Racers 8 09-28-2002 11:12 AM
