Old 10-26-2006, 01:16 AM   #1
Default Problem with rubber on carpet
HI
I run cs 22's on carpet and have always had the problem of about 3 mins into the race the tires start to squeal, then the car becomes loose and overly agressive and pretty much impossible to drive. I presume the tires are over heating. If any one has any things i can try to stop it i would be mroe thna gratefull.
Cheers
Xrayskid is offline   Reply With Quote
Old 10-26-2006, 01:37 AM   #2
shift's Avatar
the tyres are over heating. buy some cs27's and that will solve the problem but you may need tyre warmers to bring them up to temp for the start of the race
shift is offline   Reply With Quote
Old 10-26-2006, 01:49 AM   #3
changing tires isnt an option as they are a set control tire, so i need to make a set up change.
Old 10-26-2006, 01:59 AM   #4
TheCoolCanFanMan's Avatar
Hi
Get rid of some grip from your car, so that your tyres do not overheat as you get into the race, as you obviously have far to much grip from the offset.
Cheers Malc TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-26-2006, 02:03 AM   #5
Charles Godwin's Avatar
Put some harder springs on.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-26-2006, 02:31 AM   #6
Patriiick's Avatar
One classic way to fight overheating is to also drill a couple holes with a reamer on the inside of the wheel, to allow some airflow inside the insert.
It s easier to do when the tires are not mounted.
It helps a great deal, especially when you don t want to change settings.
Patriiick is offline   Reply With Quote
Old 10-26-2006, 06:18 AM   #7
Eirik's Avatar
I assume it's your rear tires are the main problem, so I would suggest you put a spool up front! This always helps on my car!!
You can also try a different additive, this can make a huge difference!!
I really like the Orion Purple when I have this kinds of problems, Part#ORI44100
Eirik is offline   Reply With Quote
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Rubber on low bite carpet roadrashracing Electric On-Road 33 01-07-2006 12:58 AM
Rubber Tire - Best TC for Carpet rcscrewz Electric On-Road 10 12-20-2005 07:45 PM
Rubber on Carpet? edseb Electric On-Road 2 05-08-2005 03:43 PM
oneway for rubber on carpet rc_square24 Electric On-Road 8 06-06-2004 02:43 PM
