Old 10-24-2006, 08:24 PM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default switch to lipo?
what type of battery is best for running a brushless motor in long runs? as in endurance races and long practice runs. sould i use a lipo or a nimh. which one will last longer and work better?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 10-24-2006, 08:33 PM   #2
Trader Rating: 38 (100%+)
Lipo will last longer. I ran a platinum 4800 lipo with a novak 4300 in an enduro and got about 19 min per charge.
or8ital is offline   Reply With Quote
Old 10-24-2006, 08:37 PM   #3
only 19 min? i can get about 25 out of a 3000nimh. but how many cells were there. and how long does it take to charge?
Old 10-24-2006, 08:47 PM   #4
Its all in how you gear it. I had to gear mine to keep up with Nitro cars but not too much so that it would thermal. You have to balance the extended run time versus slower laps. My team ran two electrics and we were by far faster then all the rest of the teams. Unfortunately we had some bad luck and ended up 3rd. 100 laps into it we were up 5 laps in a 500 lap race.
Old 10-24-2006, 08:49 PM   #5
edseb's Avatar
25? That's alot. I guess it would also have to do with how tight and technical the track is, but 19 seems the norm for that motor and battery (BL4300 lipo) configuration. I've done a couple of enduros and never heard of anyone getting that much runtime, especially with something like 3000s.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-24-2006, 08:54 PM   #6
its the neo-one sensored motor. it will run a logn time. how long will it take to charge a big lipo? and about how long will it last on the sensored brushless with a 9.4 or so gear ratio?
Old 10-24-2006, 08:55 PM   #7
Did you actually time yourself at 25 min or is that just how it felt? I know 19 min felt like an hour. I would be surprised by 25 min with 3000mah batteries unless you are geared very conservatively and it is an easy track.
Old 10-24-2006, 08:57 PM   #8
edseb's Avatar
I noticed you are also in to drifting. Your run time wouldn't be based on a drift car would it? That's a completely different thing if you are.
Carl Hyndman
Old 10-24-2006, 08:57 PM   #9
The Novak 4300 is sensored as well. The platinum 4800 takes about an hour to charge. We each ran 2 of them but we should have ran 3 of them each (6 total). You will want to get a full charge in them. At times we didnt have a full charge and they seemed to dump faster.
Is this a team enduro or individual?
Old 10-24-2006, 08:59 PM   #10
edseb's Avatar
Also, from what I understand the Neo-one is stronger than a 4300, so that run time is even more unbelievable.
Carl Hyndman
Old 10-24-2006, 09:21 PM   #11
it wasnt a full 25 min. probly more about 20 or so. the neo-one is a strong motor, but it is very efficient so... and it wasnt on a track, but it was constant movement like a race. it wasnt drifting either. trust me ive been in both worlds and know the differences in run times and all. if i had a 4300 nimh, would it last as long as the lipo? and would it take the same time to charge? or would it take longer?
individual enduros. only about 100 laps instead of the 5-8 minute races.
my gear ratio is between 9.3 and 9.4 for the final. and it is a 18 pinion to a 75 spur.
Old 10-25-2006, 05:37 AM   #12
My experience is lipo takes longer then nimh to charge. The 3200 lipos are supposed to be equivalent to a 4200 nimh so a 4800 lipo I suspect would be like a 5800 nimh. There are a couple of lipo threads on here with good info.
Old 10-25-2006, 08:04 AM   #13
It depends on the lipo and the charger if they take longer to charge than a nimh. In general the lipo will last a little longer for the same MAH of battery. The IR tends to be better and the voltage drop is less. Now if you are looking at high end nimh then I would assume over the length of the packs they would be almost dead even. I have charged my lipos 7 or 8 times in a day. From a drain it takes a about an hour. The last 10% takes the longest. Some chargers handle this better then others.
nichocgn is offline   Reply With Quote
Old 10-25-2006, 08:24 AM   #14
Rick Hohwart's Avatar
LiPo should last much longer (30%) than equivalent high quality (GP or IB race cells)NiMH. It will be even longer versus low quality NiMH.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 10-25-2006, 02:26 PM   #15
so a 4300 lipo will last 30% logner then a 4300 nimh? are they more expensive?
TEAM LOSI LIPO REGULATOR WITH SWITCH carlo71 R/C Items: For Sale/Trade 1 08-22-2008 09:49 PM
Most cost effective way to switch to lipo? xlgraphicspro Nitro Off-Road 6 05-21-2008 07:40 AM
Making the switch to lipo Tree Nitro Off-Road 15 04-11-2008 11:25 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
