bad Diff balls
Old 10-20-2006, 05:13 PM
  #16
AM03GT's Avatar
if you're drifting and you HAVE to mak the spool to keep running... make the spool and run it in the rear with the diff in the front...
AM03GT is offline
Old 10-20-2006, 06:59 PM
  #17
streetracer745's Avatar
rear spool? ive never thought of doing that. should i keep the diff up front tight or should i leave it alone?
streetracer745 is offline
Old 10-20-2006, 07:43 PM
  #18
AM03GT's Avatar
run the front diff normal setting, as smooth as you can get it while not slipping...
AM03GT is offline
Old 10-20-2006, 08:31 PM
  #19
ok cool. but will i be able to run a spool foir racing too? i mean will it mess anything up if i run rear spool for a race? and if i get a 1way will that help it?
Old 10-20-2006, 08:34 PM
  #20
AM03GT's Avatar
depending on your type of "racing" ... do you mean drift racing??? for drifting and drift competitions i'd say go for it... personally i have only done drifting a few times for fun but ideally i think front one-way rear spool would be a good setup if done right...
for road course a differential is definitely more optimal...
AM03GT is offline
Old 10-20-2006, 10:21 PM
  #21
diff in the rear or both? because ive heard front one-ways can help on a street course.
Old 10-20-2006, 11:39 PM
  #22
AM03GT's Avatar
diff in the rear... on a "street" course with decent grip a one-way is usually the hot ticket.
AM03GT is offline
Old 10-21-2006, 12:31 PM
  #23
ok ill try the spool in the back for a while. thanks for the tips
