Old 10-20-2006, 07:18 PM   #61
quantum's Avatar
Originally Posted by mini-dub
I'm having trouble believing this, did he actually tell you directly? Because everywhere I have run rubber tires on medium to high traction carpet or asphalt (not that I really ever run rubber tires.... LOL ), a used tire is going to make more traction than a new tire.
yes he did tell me, and if you ask him he will tell you too! also, you can get it directly from the horse's mouth here rubber tire thread on page 3, post#66. keep in mind the tire last year was cs27 which stays very consistent in traction for many runs. the rp30 makes more traction in the initial run but drops off more significantly in subsequent runs
...Reason being, as a tire gets more heat cycles and compound cycles the tire breaks down from the compound, which is what compound does, it softens the rubber by breaking it down and making more grip. So after a few runs the tire is significantly softer from the rubber being broken down making a worn out tire have more traction. This is a little different though on low traction, but that's not what we're talking about. But it is true gluing the sidewalls will take away side bite. But a fresh set of tires will always traction roll less than a used set.
that might be true sometimes under certain conditions, but if that were always the case, then we wouldn't be hearing all the claims here about the tires only being good for a few runs.
quantum is offline   Reply With Quote
Old 10-20-2006, 08:20 PM   #62
jw
jw's Avatar
Originally Posted by fast-ho-cars
JW - how many sets of 4 tires were drivers limited to at the IIC. were they numbered/assigned to only that driver?
Hi fast-ho-cars - 4 sets per driver per rubber tire class entered were allowed to be purchased. The tires were marked and labeled with a sticker with drivers name, class and set number & the IIC logo.
jw is offline   Reply With Quote
Old 10-20-2006, 08:40 PM   #63
AM03GT's Avatar
as far as more traction as a tire gets old goes...
im no chemist or material scientist so i cant tell how this works chemically...
but more traction as the tire breaksdown and gets softer only applies in an ideal situation where the tires material makeup and chemical structure stays the same. this is not the case as the tire goes through heat cycles the actual rubber compound goes through changes due to the heat cycles... i mainly have experience running sorex 36r's on high traction asphalt and what is seems is that as the tire gets more cycles it does get softer overall and loses sidewall stiffness but the rubber loses its "stickiness" i.e. after the first run using paragon you can pull the car off the track and the tires are very sticky... but on an old set say 15+ runs you can pull the car off the track and the tires come off almost dry and not much tack...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 10-21-2006, 06:19 AM   #64
bozla's Avatar
I love rubber and asphalt. To keep the tires useful you have to manage them correctly. Obviously I practice on my old sets and keep my new ones for the races. If you prepare them by using a tire sander before each run and clean them down after with parts cleaner, they come out pretty new.
bozla is offline   Reply With Quote
Old 10-21-2006, 11:55 AM   #65
This all opinions and perceptions. Where I race the sportsman (novice) stock and stock classes went to rubber tires on carpet. So I don't race TC any more, I hate the idea of deevolving a class or classes in the name of a false economics move. Now, before the haters start, I tryed it and broke more parts and peaces after buying more parts to set up the car for the softer set up for rubber than I ever did running foams in a season. The result one less racer and less support for the local track. Why should I spend MY money to race and support a track that doesn't care.
lumberjak is offline   Reply With Quote
Old 10-21-2006, 01:03 PM   #66
sportpak's Avatar
Trader Rating: 26 (100%+)
Personally, I found before I could go fast on rubber tire, I had to slow down and learn about chassis and finess. If you went out there banzai, used to foam tire traction, it's no surprise you broke a bunch of stuff.
Maybe if you talked to your local track about running foam tire they would let you. Here, if we have 4-5 guys running something, you have a class, and are more then welcome to race. Instead of tearing the place down, try being civil about it and Im betting you'll come up with something.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 10-22-2006, 09:57 AM   #67
tim fry's Avatar
Hi all
What bodies are you guys using with rubber on carpet?
All I see is Mazda 6
tim fry is offline   Reply With Quote
Old 10-22-2006, 10:58 AM   #68
Send a message via AIM to A-Ko
The only thing foams are good for are Tire Inserts, pan-cars and Factory Drivers.
On a club level there is really no room for foam, you chunk-it you junk-it has been my slogan for foams.
Plus people who say foams last a long time, what do you say to those who true theirs down to the rim to make their cars handle better. . .
Jeffrey
teamgravityrc.com - motivrc.com
USVTA National Points Member #101
A-Ko is offline   Reply With Quote
Old 10-22-2006, 11:49 AM   #69
Hustler's Avatar
Originally Posted by sportpak
Holy crap, it's Dave, it's one of my people!! I thought was on here all alone. Go on, tell them how much fun rubber tire racing is.
You assume too much Ben.
-Sean
Hustler is offline   Reply With Quote
Old 10-22-2006, 12:20 PM   #70
sportpak's Avatar
-Sean
It's another one of my people! Good to see you Sean. What do you think about rubber tire?
Old 10-22-2006, 12:32 PM   #71
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Srry to hear you quit because you can't stay off the walls. What kind of car do you own that you had to buy parts to setup a car to be softer besides springs and oils?
Dasupacat1 is offline   Reply With Quote
Old 10-22-2006, 09:03 PM   #72
robk's Avatar
Trader Rating: 22 (100%+)
Chunks glue back in, I have done it many times. Even if you can't find the piece, you can cut one in from an old tire.
Again, if you want to go fast, you can true the tires down. If you want to go fast in rubber, you will put on a new set every 5 runs (every race day). There is no difference. Speed = $$$
Old 10-22-2006, 09:30 PM   #73
Trader Rating: 18 (100%+)
Giddyup....GIDDYUP...I SAID GIDDYUP DAMN IT!!!!! *WHIP* *WHIP* *WHIP*
This damn horse just won't go anywhere!!!!!
sigh.......
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-22-2006, 09:56 PM   #74
BlackKat's Avatar
sigh.......
Gee Art, your horse died....maybe you shouldn't gear him at 5.5
BlackKat is offline   Reply With Quote
Old 10-23-2006, 09:57 AM   #75
LOL
Killer Packs + 140 degree track temp + 95 degree ambient temp + 5.5 final drive = magic smoke released from motor.
It sure was fast for 4 minutes though....
Touring Carpet Season: foam or rubber tires? ShaunMac Georgia Racing 69 03-09-2012 01:31 PM
7 week lay off sale CORALLY PHI fully loaded,asphalt,carpet,foam,rubber ehlert R/C Items: For Sale/Trade 14 05-08-2008 12:59 PM
Rubber vs Foam carpet setups? beerbarron Electric On-Road 1 11-03-2005 05:50 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
tires for carpet rubber vs foam sportracer Electric On-Road 6 01-21-2003 09:06 PM
