Old 08-17-2007, 09:40 AM   #136
sportpak's Avatar
Trader Rating: 26 (100%+)
Another tricky part of rubber TC racing on carpet is that most of the time your car is overpowered. So chassis setup and a smooth driving line is crucial to being able to put that power down and separate yourself. I watch the foam guys at my track closely. They're a little faster, but throttle is herky jerkey, lines are vague, and breakage seems to be more likely. When some of those guys switched to rubber, while it got ugly for a while, they ultimately smoothed out and got fast. Now when they run foam they are even faster then they were before. I know world level guys make it look good, so everyone racing foams take it easy, I'm not bashing foam TC. When I want to go fast I race 12th scale.
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 08-17-2007, 10:46 AM   #137
Yeti35's Avatar
I agree in that rubber on carpet teaches you to be smoother and more accurate since your traction is limited and you have to be. I was learning that when our track was open and before we ran on it I said about doing rubber classes and everyone just looked at me. They then saw how fast you can go on carpet with rubber but also it took a bit more skill to do so.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-17-2007, 08:10 PM   #138
nashrcracer's Avatar
R/C Tech Charter Subscriber
so I have to buy 5 different sets of rubber and insert combo to get the right combination for what tempeture it is. and then they fall off like was said after 3 or 4 run .02 a lap so if someone else puts new tyres on for the main I have to put new tyres on also. I can get consistant low 10 second laps at our track from 2.25" to 2.10" and get about 3 or 4 weekends out a set of foam tires. so i have to change my droop and ride height. it's the same as if i was running 12th scale. and like I said if foam is good enough for nitro touring and 12th scale it's good enough for electric TC I'll just keep buying my double pink double pink orange jacos and be happy.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 08-17-2007, 08:21 PM   #139
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Foam rules. I just never could get into the rubber racing.
I have the best all round longevity and performance running foam.
I don't see how rubber could take over with out some drastic change in the performance longevity.
All though there was some rubber tires on a thread the other day that were half the going prices. Thats a plus...
UN4RACING is offline   Reply With Quote
Old 08-17-2007, 09:04 PM   #140
syndr0me's Avatar
Trader Rating: 32 (100%+)
I don't think I'd be interested in rubber without a spec tire. I think that's one of its greatest virtues.
syndr0me is offline   Reply With Quote
Old 08-17-2007, 09:09 PM   #141
UN4RACING's Avatar
I prefer to mix and match the compounds like foam. Never did like 4 of the same.
One more reason I don't run rubber.
Old 08-17-2007, 09:12 PM   #142
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
I don't believe anyone has touched the fact that rubber tires don't lay down a groove compared to foam. Without foam tires, racing becomes a lot slower for the rubber guys.
Sean R is offline   Reply With Quote
Old 08-17-2007, 09:18 PM   #143
UN4RACING's Avatar
As a foam racer I feel the same about rubber racers. Theres a lot of pluses to rubber. I would say they are a better alternative for the true budget racer.
But if trying to run up front and fast as possible ya just cant beat the foams.
Old 08-17-2007, 09:41 PM   #144
sportpak's Avatar
I don't think one would/could ever replace the other. It is a apples and oranges kind of thing people need to keep in mind. As long as each side respects the other for it's differences all should be good. People should try both and run what they enjoy.
Old 08-17-2007, 09:56 PM   #145
C_O_jones's Avatar
syndr0me, try the Speedmind/Sorex 28 premounts, they last a lot longer than the CS27's with much better traction.
Our indoor series went from CS27's to the Speedminds last year and everyone was a lot happier, for a spec premount, they are the way to go.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 08-17-2007, 09:57 PM   #146
UN4RACING's Avatar
Thats some good advise to practice right there.
Its good to change up from time to time to.
Old 08-17-2007, 09:59 PM   #147
UN4RACING's Avatar
I always had good luck and they last to. I'm not sure if its the belt or just the rubber.?
But the belts are awesome with a mod motor.
Old 08-18-2007, 01:26 AM   #148
syndr0me's Avatar
The rest of the world seems to do okay on rubbers, and they're not exactly slow. Check out the modified videos.
http://www.racerc.dk/modules/content/index.php?id=22
Old 08-18-2007, 06:43 AM   #149
Trader Rating: 27 (100%+)
I have heard that several times, but the local track insists on cs27's. The Sorex's are even cheaper from what Ive seen
convikt is offline   Reply With Quote
Old 08-18-2007, 07:18 AM   #150
UN4RACING's Avatar
I guess its all in order to keep it fair. You could try to make the Sorex the speck tire. Usually 3 0r 4 dollars cheaper, and if you can get an extra week,? 5 or 6 dollars cheaper. I think 27's have become the main one cause thats what the big races use.
Around here we can buy orion tires sorex and every rp tire, but you can only race 27's. At the local shop in north town they have a box full of tires 1.00 each. All the 27's are gone and none will by the others. Waste of money when you cant even bash them.
You would think at 1.00 each they would be gone in a New York second.?
Touring Carpet Season: foam or rubber tires? ShaunMac Georgia Racing 69 03-09-2012 01:31 PM
7 week lay off sale CORALLY PHI fully loaded,asphalt,carpet,foam,rubber ehlert R/C Items: For Sale/Trade 14 05-08-2008 12:59 PM
Rubber vs Foam carpet setups? beerbarron Electric On-Road 1 11-03-2005 05:50 PM
Rubber Tire vs. Foam Tire on Carpet dizzy1 Electric On-Road 34 06-07-2005 02:51 PM
tires for carpet rubber vs foam sportracer Electric On-Road 6 01-21-2003 09:06 PM
