Old 10-18-2006, 11:41 AM   #1
Default Touring Car use Foam tire ?
F & R how many mm & F & R same DEG ?
capeta is offline   Reply With Quote
Old 10-18-2006, 12:13 PM   #2
RaceAce701's Avatar
Trader Rating: 86 (99%+)
i start with 58mm and rin it till about 55m or till the tire chunks
same size front and back
different size tires can do funny things to a car
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-18-2006, 12:30 PM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
f & r got fast and same. small smooth lift not.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 10-18-2006, 01:37 PM   #4
Use 26mm foam cut to φ58mm ?
Rear tire same ?
Old 10-18-2006, 01:44 PM   #5
RaceAce701's Avatar
i run 38 shore in front and 35 shore in rear
or DBL pink orange front and DDL pink rear
trued to 58mm
Alex "ACE" Kubilus
ACE design works
Old 10-18-2006, 02:10 PM   #6
F & R same is 26mm width ?
or use resr tire cut to 26mm ?
Old 10-18-2006, 02:12 PM   #7
RaceAce701's Avatar
same width front and back
i use the width right out of the package
what brand are u using
parma and jaco are good i use grp
what car are u driving
Alex "ACE" Kubilus
ACE design works
Old 10-18-2006, 02:14 PM   #8
vtl1180ny's Avatar
I'm guessing you're running on carpet....
Nitro Foams are the only foams where you will run a 26mm wide front and 30mm wide rear.
I run TRC and they are 28mm wide. Usually Cyan Front and Magenta Rear on my LHS's track. ( Dbl Pink and Dbl Pink/Orange with Jaco's)
You need to see from other racers what compound works where you are running.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 10-18-2006, 02:15 PM   #9
seaball's Avatar
when buy big not small and theirs difference. wat you say that?
Old 10-18-2006, 02:17 PM   #10
Do I hear Yoda?
jeffb is offline   Reply With Quote
Old 10-18-2006, 02:18 PM   #11
I'm is use Cyclone
but rear foam tire is use same front compound or use wide 30mm rear cut to 26mm tire ?
GRP !
Thanks!
Old 10-18-2006, 02:24 PM   #12
Carpet 28mm front
28mm rear
Old 10-18-2006, 02:45 PM   #13
RaceAce701's Avatar
you can run 30mm but the 28mm help the car transition better
i use grp becaue they come in 26mm width an the works best on my track
http://www2.towerhobbies.com/cgi-bin...?&I=LXMWW6&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMWW7&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMWX0&P=7
i also drive a cyclone
Alex "ACE" Kubilus
ACE design works
Old 10-18-2006, 02:55 PM   #14
RandyB's Avatar
And type sea dragon is like cut off 55mm forward to shopping
RandyB is offline   Reply With Quote
Old 10-18-2006, 02:58 PM   #15
can't use 30mm tire touch shock ball end !
how ?
~*~*~TOURING CAR FOAM TIRE LOT~*~*~ NErc10 R/C Items: For Sale/Trade 11 11-15-2006 06:31 PM
~*~*~*Touring car Foam tire lot*~*~*~ NErc10 R/C Items: For Sale/Trade 14 10-19-2006 05:40 PM
Foam Tire lot touring porschejim911 R/C Items: For Sale/Trade 5 09-14-2006 06:04 AM
**Foam Touring car tire lot** racingkd R/C Items: For Sale/Trade 10 02-06-2006 01:49 PM
1/10th Touring Foam Tire Lot RCNitroDude999 R/C Items: For Sale/Trade 0 02-13-2005 07:31 PM
