Old 02-12-2003, 09:02 AM   #1
bruisedwillis's Avatar
Lightbulb Pro Trak Version 6
Hi all
Any comments on this charger?
What is the charge and discharge rate?
What is the pros and cons?
Does this charger has any limitations on cell capacity?
Will it shows the full capacity if I am using a GP3300 and peaking it up to 3600mah?Meaning is the display on capacity inifinite?
Can it be upgraded to newer version, if can how to and price?
bruisedwillis is offline   Reply With Quote
Old 02-12-2003, 11:06 AM   #2
It is very good i have 2 years now with out problems. It has a limitation of 8 cells. you dont have a problem of peaking or charging 3300 cells. it can go more than 5000 ...dont worry.
You can upgrade it very easily by changing a small chip.. for info about the prices go to his site
http://www.pro-trak.co.uk/
Harris
harris is offline   Reply With Quote
Old 02-12-2003, 06:45 PM   #3
Harris
The upgrading cost a bomb.... Is yours the version 6....can I say that the display can read up to 5000mah is the pack is 5000mah...meaning display capacity up to 9999mah?
Old 02-13-2003, 05:50 AM   #4
sosidge's Avatar
I don't know what features version 6 has, but the charge rate is very adjustable, the discharge rate is 20A, and the charger should be adjustable to charge 3300's (just use the right peak delta)
Old 02-13-2003, 07:46 AM   #5
dtm
dtm's Avatar
Send a message via ICQ to dtm
Find someone who has a newer version...you can copy the EEPROM with an EEPROM writer.....easy to do...no problem going from 6.45 to 7.xx......
dtm is offline   Reply With Quote
Old 02-15-2003, 06:04 PM   #6
Hi all
Does the version 6 comes with the heat sensor on the heat sink and is it useable with the tempeture detect module without sending back it to do modifications?
Regards
Old 02-16-2003, 03:25 AM   #7
All modifications and upgrades can be done by the end user, there is no need to send it back to Pro Trak
Mort is offline   Reply With Quote
Pro Trak NismoSkyline17 Electric On-Road 520 11-09-2009 08:33 AM
Pro Trak BMS chrisHN Singapore R/C Racers 0 12-05-2007 04:33 AM
APS 3 in 1 dyno charge, Older version vs Newer version Marc_05 Australian Racing 0 09-18-2005 05:43 AM
Pro Trak Version 6 with TEMP detect module and heat sensor on heatsink bruisedwillis Electric On-Road 2 02-16-2003 06:26 AM
Pro-Trak Is The Best CRASH Electric On-Road 5 04-13-2002 06:36 PM
