Old 10-15-2006, 05:32 PM   #1
Default noob Question on motor turns ???
hey guys im new into this stuff. wats the meaning of turns limit?
i have cheap Futuba magnum. just started 4 days ago.
can u please explain. i heard that if i upgrade motor i need to know my limit turns. why?
im willing to upgrade better remote for a good motor.
deadhero is offline   Reply With Quote
Old 10-15-2006, 06:40 PM   #2
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Number of turns is number of winds on the motor armature.modifieds are usually between 6 - 17 turns, superstock is 19 turn (thats what i run) and i believe stock is 27 turn (someone correct me if im wrong!)
If you go for a lower turn motor than your currently running you will need to know what the lowest number of turns your ESC can take, if you go any lower than that you will cook your esc. Also the remote is not linked with the number of turn limit of a motor, just the esc.
Hope that helps!
JAY_UK is offline   Reply With Quote
Old 10-15-2006, 06:48 PM   #3
first to know what gear ratio to use(but this is still not useful to you as of now)
and second to know what class you belong.( one again dont bother.)
on your present state now. just buy a stock motor its a 27 turn its for beginners( just generalizing.some stock motor are so fast too.)
motor limit is useful for your esc. not your radio.
if you check your manual for your esc . some esc has no motor limit and some has.
for example if you have a duratrax 8t esc. the 8t is the hight motor turn it can handle.
if your esc has no motor limit that means??? ......... your right no limit.
motor turn: all motor has turn. that is the number of coils on the armature. the smaller the turn (27t -> 8t) the faster the motor. the higher the turn (8t-> 27t) the slower it goes.
jinkasama is offline   Reply With Quote
Old 10-15-2006, 07:40 PM   #4
thnx guys thats helps alot. this forum is so helpful.
Brushed motor turns to Brushless Motor turns raedat Australian Racing 15 10-25-2007 09:06 PM
got a noob question... ratcoon Rookie Zone 8 12-19-2005 05:46 PM
Noob Question Zala Electric On-Road 3 01-05-2005 09:34 AM
noob question siulung100 Electric On-Road 3 12-18-2004 03:24 PM
noob question about Motor Armature aoizip Rookie Zone 3 05-16-2004 08:51 PM
