Old 10-12-2006, 11:00 PM   #1
Default Interpreting data from a motor monitor
I have just bought a motor monitor, another toy to play with!
How do I interpret the data I get from it; it gives Amps and RPM, Max RPM and Max Amps. It is one of the Much More /Orion ones and stages the voltage as it tests the motor at 1.2V, 2.4v, 3.6v, 4.8v, 6.0v and 7.2v.
What am I looking for to tell if the engine is good, high Amps, RPM or a combination of both.
Also what sort of numbers do you get from a good stock motor and a 540 Johnson.
PRO 2 RACER is offline   Reply With Quote
Old 10-12-2006, 11:12 PM   #2
XrayFK's Avatar
High amps usually indicate a strong motor, however with no load it's not always an accurate assessment of a motor. A good motor could pull low amps, but be fast on the track. Likewise, a motor could pull 10+A but be a dog. The best way you can use the motor monitor would be to compare motors on it to the numbers you get from a motor that you know performs well on the track. Also, make sure nothing is binding, because that will make the motor draw more amps. (squeeze the armature when its running and the amps will shoot up)
Hope this helps somewhat, someone else will have to help you with the silver can, I don't jack about those.
XrayFK is offline   Reply With Quote
Old 10-19-2006, 07:39 PM   #3
Default Motor Monitor Numbers
Has anybody got any numbers from their own testing of motors on a motor monitor.
I am after a Johnson motor & a CO27, and maybe a monster. Amps & RPM.
Old 10-20-2006, 01:23 AM   #4
RocketRacer's Avatar
Team Integy Indi Dyno V2
i tested the motors at 7.2V
CO27
Max Amps : 7.34
Max RPM : 32700rpm
540 (4 slot)
Max Amps : 1.35
Max rpm : 19000rpm
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 10-20-2006, 01:31 AM   #5
sorry to change subject but
CO27
Max Amps : 7.34
Max RPM : 32700rpm
540 (4 slot)
Max Amps : 1.35
Max rpm : 19000rpm
but this really suprised me the difference i new it was there but not some13000 rpm wow, cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
FS: NIB Orion Motor Performance Monitor 2 revolution31 R/C Items: For Sale/Trade 9 03-31-2008 10:58 PM
WTB: motor monitor/ preformance monitor dingosrun Australia Wanted to Buy 0 01-15-2008 03:35 PM
MuchMore Motor Cooler + Orion Motor Performance Monitor mugengreg Australia For Sale/Trade 11 01-05-2008 09:56 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Indi motor dyno vs. Orion Motor Perf monitor j240z Electric On-Road 5 08-07-2004 03:58 PM
