Silicon density comparation chart
Hello Friends,
I have seen that there are many manufactures of silicon oil that use different units to measure the density, does any one know thye equivalence? so it will be easier to compare the asso, serpent, xray, losi, ... oils. Thank you |
poop
there's not really good chart to use, because the data mostly sucks. i had used a nice Brookfield rheometer ($20K) to gather this data, and i was fairly disappointed. here are general conclusions for a few popular oils.
trinity is lightest and linear in steps assoc and losi are similar and linear in steps hudy/serpent is generally heavier and exponential in steps all of the oils tested exibited crappy qc. we had some oils that were out of place in nearly every brand, eg.: 60 > 70. my advice is to copy the brand on the setup, or if you are doing all your own tuning, get a few bottles of each weight and combine them. that way you will have enough of the same silicone oil for the life of the car. - jr levitz - |
trinity is lightest and linear in steps assoc and losi are similar and linear in steps hudy/serpent is generally heavier and exponential in steps all of the oils tested exibited crappy qc. we had some oils that were out of place in nearly every brand, eg.: 60 > 70. my advice is to copy the brand on the setup, or if you are doing all your own tuning, get a few bottles of each weight and combine them. that way you will have enough of the same silicone oil for the life of the car. - jr levitz - Did you also check the Losi Certified shock oils. Are they the real deal? |
| All times are GMT -7. It is currently 11:24 AM. |
