Old 10-10-2006, 08:51 PM   #1
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
Default need pic with fan mounting
hi i just need to see how you guys mount your fan without buying those coolcanfan fan mount.. is the excess lexan cutoff from the body works? just want to see some photos.. i will appreciate it.. thanx
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 10-10-2006, 08:57 PM   #2
Kropy's Avatar
Send a message via AIM to Kropy
Check out the Fan & Mount that Trinity has. http://www.teamtrinity.com/shop/maintenance/motor.html
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline   Reply With Quote
Old 10-10-2006, 09:20 PM   #3
pinggoy's Avatar
thank you for that link. but i just want a simple home made one.. im saving up. and my fan is 1 1/5 inches... thanx
TAMIYA TRF416X
Old 10-11-2006, 10:17 AM   #4
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
Yup, I got mine from spare body molding, or just a piece of plastic from either a pop bottle, or anything packaged with thick plastic (like those clamshell-sealed-types-that-you-have-to-annihilate-in-order-to-open kinds)
Thankfully mine actually has an open screw hole on the top of the motor mount, works like a charm as a mount. Just needed to make sure it's far enough from the can's magnetic field... it's just held on to 2 of the screws, and the mounting hole is coated with Goop to prevent sliding around. It's directed right above the can holes..
-=≡ Tamiya TA05 TRF415MSX F103R M-03R M-04 M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 OFNA LD3 Pro Fastcats Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 10-11-2006, 10:48 AM   #5
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
James, one thing that someone mentioned to me which rang true. With fans over the can, its better to suck the air than push more on it due to the arm rotating. With all the turbulent air from the arm, its easier to suck out the hot air, than push cooler air in. Seems to work. I use two fans, one that sucks out of the can, and one that blows into the positive side of the endbell. Ive been using my motors hard and they havent over heated.
Aaron "AJ" Freind
axle182 is offline   Reply With Quote
Old 10-11-2006, 11:57 AM   #6
pinggoy's Avatar
thanx james... yup i think its better to suck air on top of the magnet. i have a fan before and it just stop turning. ithink its because of the airflow since the air from the can pushes air.
TAMIYA TRF416X
Mounting a Mamba Max ERustler Electric Off-Road 9 09-12-2007 12:35 PM
Wing Mounting atxgman Electric On-Road 8 06-08-2007 06:47 AM
Mounting a Fan surrealmaterial Electric On-Road 30 01-24-2007 07:22 PM
Receiver mounting? Racingfreak6 Electric On-Road 4 08-19-2006 07:19 PM
Fan mounting Mark G Electric On-Road 4 06-06-2006 12:41 PM
