Old 10-10-2006, 05:19 AM   #1
Setup problems
Hi
I am racing indoors on carpet using foam tyres (37 rear, 42 front), TRINITY MONSTER PRO 27T motor and a Tamiya EVO IV MS.
What camber angles and front/rear springs does everybody ring?
I am currently running -2 degrees camber front and rear, but the front tyres are turning into a cone shape (narrow on the outside!!). How can I correct this without adding even more camber
simon_allen is offline   Reply With Quote
Old 10-10-2006, 05:23 AM   #2
sosidge's Avatar
Stiffer front end will help.
Old 10-10-2006, 08:13 AM   #3
Trader Rating: 21 (100%+)
Originally Posted by simon_allen
Hi
coning-way too much body roll.As sosige said stiffen it up.You should be in the 35-40 range in the front about the same rear.Spring tensions.Oil try running 40-50 wt.Start equal fr/rr.soften rear a bit if more traction is needed.You can also limit roll with camber rod lengths.Try slightly longer than you have now if the spring/oil combos don't do it completely.Let us know how it works out.Mario.
lotus1 is offline   Reply With Quote
Team Integy Setup Station 2 w Case and setup board - complete olhipster1 R/C Items: For Sale/Trade 4 11-02-2007 08:21 PM
XRay T2 Rubber setup, RC 10L4, 1/10 on road setup station jsmax R/C Items: For Sale/Trade 36 04-16-2007 08:56 PM
Setup Thread, Problems and Advice joamu Electric On-Road 8 02-22-2007 11:21 PM
almost prospec mbx5 f/t with engine for nitro touring setup or electric setup tony montana R/C Items: For Sale/Trade 13 02-03-2006 12:42 PM
Trinity Tru Lathe Setup Problems tminus3 Electric On-Road 27 04-05-2005 11:47 AM
