Tamiya TEU-101BK ESC Questions? >
Old 10-08-2006, 02:44 PM
Default Tamiya TEU-101BK ESC Questions?
I Have a Tamiya TA-05 running a Tamiya TEU-101BK ESC and a Tamiya Black Sports Tuned Motor. I want to try other motors but don't know if the ESC will handle them. I have been given a 27t Epic motor and a Tamiya GT 25t motor. Can I use any of these motors with this ESC or not. What turn is the Sports Tuned Motor?
Alashar is offline
Old 10-08-2006, 04:39 PM
secretsg's Avatar
ESC is rate for 27T but should handle a 23T no problems. 60Amps is the limit. Sports Tuned US/Japan version is 27T. European version is 23T.
secretsg is offline
Old 10-09-2006, 02:15 AM
Thanks secretsg, I will give the two motors a try and see what happens.
Alashar is offline
Old 10-09-2006, 03:35 AM
sup
sup's Avatar
i sent an email to tamiya a few months back with the same question, teu-101bk can handle upto the sport tuned motor only. hope im not too late.
sup is offline
Old 10-09-2006, 07:25 AM
rampal's Avatar
I use the TEU-101BK with a Tamiya super stock RZ (23T), with no major problems.
rampal is offline
Old 10-09-2006, 10:16 AM
umm im not so sure i have a friend thats been running a 16t on his this esc and its been working fine so i tihnk this can handle a little mroe than a 23t
C_Suzuki is offline
Old 10-09-2006, 10:26 AM
edwintklee's Avatar
Trader Rating: 23 (96%+)
hey bro, at what ratio??? can do about 5.4?? on my gtx the motor temp is about 67c, measured with a temp gun
edwintklee is offline
Old 01-29-2007, 03:34 PM
nikkiesteban's Avatar
did you put any modification in heatsink or add a heatsink?? i want it to try also w/my superstock rz 23t.. and how long did you ran your car? and i will be running 5.4 gear ratio for the teu-101bk... or anyone here tried this??
nikkiesteban is offline
Old 01-29-2007, 05:00 PM
forum fodder's Avatar
The TEU101 will run motors hotter than the RS540 sport tuned, which is not 27T in Japan, its 23T same as Europe and i expect the US ones are the same as well. The big problem with using this speedo with hotter motors is it will expire a lot sooner. These speedos do go off, and even with a sport tuned if given a hammering it will deteriorate.
forum fodder is offline
