Old 02-11-2003, 03:17 PM   #16
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Switch Blade, I do not recommend getting the novak with the black box. The black box only puts out 4.5 amps, which if you're even half-way serious about going fast is not enough. 4.5 amps will take about 45 mins to charge a 3000 pack. A 5-6 amp charge rate is preferable for most club racing.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-11-2003, 08:10 PM   #17
Switch Blade's Avatar
Send a message via AIM to Switch Blade
dang, this is harder than i thought.....is the GM VIS Commander AC/DC......and where can i get info for the LRP switching power supply??
thanx for the replies
College
Switch Blade is offline   Reply With Quote
Old 02-11-2003, 09:07 PM   #18
The GM Vis is over $300 and is DC only. If you're gonna be in it for the long haul i recommend going with a Rivergate Bulldog 15 amp. You can get one directly from Rivergate for under $100. That is one of the best values in power supplies you can get. Their site is www.rivergatedist.com . I have their 30 amp supply and i love it. If you're going with the Pulsar get a power supply from rivergate or integy. Another option you could look into is the Reedy Quasar pro. That is AC/DC and is $169.99 most places.
USVTA Member #211
Old 02-12-2003, 01:28 AM   #19
Cole Trickle's Avatar
LRP: http://www.lrp-electronic.com/ ->Products->Chargers
It's a little expensive.
However, that Rivergate thing sounds very interesting...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 02-12-2003, 03:27 PM   #20
CaptnKrunch's Avatar
I see this power supply has a few hours left.. looks like it would do the trick
http://cgi.ebay.com/ws/eBayISAPI.dll...category=11772
CaptnKrunch is offline   Reply With Quote
Old 02-12-2003, 03:38 PM   #21
Originally posted by TSR6
Im looking for a cheap computer power supply to modify. If i can get one with at least 15amps, for around $30, i'de be happy. I hear its easy to find 'em.
Usually you dont have to pay for them. Just lay your hands on an old computer, tear it apart and take out the PS unit. Then you just have to buy some resistors. I did my conversion for around 5$, including an control LED, to tell if it's turned on ! I've tested it for delivering 10 amps. Probably it will also do 15, though I haven't tested it.
Old 02-12-2003, 11:41 PM   #22
warlord385's Avatar
Default LRP Pulsar Competition
I have a question concerning the charger and charging batteries. When i charge the 3300 promatch gps i get about 3200 maH. I let them cool and then charge again and it chargers for about another 5 mins adding about 200-500 more mah. ALso when charging at 5 amps 20mv delta peak the batts are pretty warm about 123-157F. I though 5 amps was fine and it would get hot. Also on discharge the batts go down to 5.4 then when it stops the voltages goes to 7.4 volts. Wuts up with that
warlord385 is offline   Reply With Quote
Old 02-13-2003, 04:46 AM   #23
RC Nitro's Avatar
Warlord: You may want to read the FAQ on the promatch site. Good info on batteries there that Jeff wrote. Jeff Rowe PMR and Danny Sullivian SMC are the best around for batteries.
Pro Match FAQ
RC Nitro is offline   Reply With Quote
Old 02-13-2003, 11:32 AM   #24
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
I am getting my pulsar this weekend, I needed a power supply and was searching and found a guy talking about this one.
Radio Shack
13.8VDC-25 AMP Switching Power Supply for $60.00.
There on sale. 50% off normally $115.
Same as the Samlex SEC 1223.
Part # 22-510.
Myself and a friend both have bought one. 25 amps for right around $63 with tax is very nice!!!
RoachRacing is offline   Reply With Quote
Old 02-14-2003, 08:09 PM   #25
Ive heard good stuff about the integy 16X7 pro. It is ac/dc, and can charge and discharge....sounds good from me
College
Battery Charging Question xman Nitro On-Road 4 08-17-2008 09:03 PM
Battery charging question... DotyThe8ight Electric On-Road 5 12-23-2006 12:33 PM
Question Please regarding charging battery Wing Chun Electric On-Road 2 08-26-2006 03:19 PM
Battery charging question tommytman Rookie Zone 10 08-31-2005 06:13 AM
Ni-mh Battery Charging Question heyman Electric On-Road 3 03-15-2005 02:10 PM
