Old 10-02-2006, 04:23 AM   #1
Hayden's Avatar
Default Lola style body
Iím after a 1:10 scale 200mm body like this:
http://www.pro-lineracing.com/protof...1610/1610.html
Or
http://www.pro-lineracing.com/protof...609/1609-5.jpg
Is there any available from any other manufacture?
Hayden is offline   Reply With Quote
Old 10-02-2006, 05:29 AM   #2
peejay's Avatar
These are 1/12th bodies right?
Unless someone else knows better, the nearest you are likely to find in 1/10th are Tamiya Group C or Le Mans car bodies such as the Jaguar XJR or Audi R8R, and their latest offering the Courage LC70. However, these are all 190mm.
Why do you want 200mm? You running 1/10th nitro?
peejay is offline   Reply With Quote
Old 10-02-2006, 06:08 AM   #3
Hayden's Avatar
I hoped they would be aerodynamic for straight line speed runs in an electric I wonder how much difference they would fit
Old 10-02-2006, 06:27 AM   #4
academygaz's Avatar
Those Tamiya bodies don't fit most cars, the shock tower on the front gets in the way (unless you have a Tamiya F103GT).
Yokomo do/did some 200mm GTP bodies.
ZE-RHB:
ZE-RTB:
Serpent does one: http://www.mytsn.com/products/desc.asp?prid=2343
As does Protoform: http://www.pro-lineracing.com/protof...1480/1480.html
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 10-02-2006, 09:02 AM   #5
nagatahawk's Avatar
Default HI SPEED BODY.
I know people have been going to a hi downforce body for land speed records.
having run on the velodrome track I have found that the hi down force bodys will scrub speed because the hight downforce causes the car to be pressed down to the track to much. you can hear the pressure on the tires and see the slow speeds. its like adding 5 lbs of weigh or more.
The trick to high speed is not down force but aerodynamics that allow the body to flow thru the air and not push the car down excessively.
In velo oval racing a blunt nose would be preferrable rather than a pointed nose. and a pull in hips rarther than a wider rear. also a small wing, remember the down force exponential will increase on the small wing especially at 50 mph and above.
I have some ideas I will be applying to my velo body, blunt nose,with rear bumber on , rear under the trunk valence, areo wind channel above the battery tray, and a wing with small side plates. We all continue search for that areo advantage at hi speeds. just check out the Nascar stockers. they reach speeds of around 200 mph with 357 cu.in. engine pusing a 3200 lb car. open wheel would be another interesting venue. even with the open wheels the cars really fly.
good luck at what ever body style you decide. try several.
wn
nagatahawk is offline   Reply With Quote
Old 10-02-2006, 11:26 AM   #6
BimmerDriver's Avatar
http://www.pro-lineracing.com/proto.../1610/1610.html
Or
http://www.pro-lineracing.com/proto...1609/1609-5.jpg
Check out the Team Magic bodies for the LeMans cars, open and closed cockpit are available.
Team Magic LeMans
BimmerDriver is offline   Reply With Quote
Old 10-02-2006, 04:32 PM   #7
GreaseMonkey's Avatar
The Frewer Loletta is also a 200mm lola style body.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 10-02-2006, 05:32 PM   #8
Three's Avatar
Try this website:
http://www.mcallisterracing.com/racing/page10.html
or
http://www.vansinvent.com/
(this site is being updated due to a hacker/spammer)
Electric good..........
Three is offline   Reply With Quote
Old 10-04-2006, 05:58 AM   #9
Hayden's Avatar
Yes Iím after aerodynamics and not to much down force I will get some nice speeds out of a 4cell 1930 hi gearing touring car
Donít forget NASCARís are kind of like straight line racing.
you can get over 270kph out of a stand maloo ute
Old 10-09-2006, 02:27 AM   #10
Hayden's Avatar
I have found some more bodies
I like those Yokomo bodies do those come with pre-cut engine holes because my car is electric and I donít want big holes in the body
http://www.shopatron.com/img/product...7/PAR10154.jpg
http://www.shopatron.com/img/product...7/PAR10138.jpg
Lola body for MTX-4 BIGTACO Nitro On-Road 2 12-06-2006 01:47 PM
Lola body 4 FW-05R Secret_weapon Nitro On-Road 2 11-05-2005 12:35 AM
1/10 lola body Jye Nitro On-Road 46 06-23-2005 09:08 PM
lola body ntc3freak Malaysian R/C Racers 2 01-24-2005 05:42 AM
MTX-2 Lola Body cvccsi R/C Items: For Sale/Trade 4 10-12-2003 08:49 PM
