Old 09-29-2006, 06:35 PM   #1
Default Body Trimming
I have a question regarding how far you can trim the body. Previously I have always trimmed the body up so that I could mount the body as low on the car as possible. Now I have my first legal race body so I want to make sure I do it right. Does the body have to be trimmed along the lines and the body mounted at the right height for the body? Or can you mount the body low and then trim up the body? Hope this makes sense.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 09-29-2006, 06:38 PM   #2
AM03GT's Avatar
you dont want to mount the body too low and cut off aerodynamic features like front lips. mount the body so that the cut line for the body is right around the bottom of the chassis at ride height. from there use a regular sharpie marker and roll it along the bottom of the body. if you cut on the sharpie line its usually right around ride height to the bottom edge of the body...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 09-30-2006, 08:46 AM   #3
imjonah's Avatar
Default Roar Legal
ROAR has a minimum height restriction http://www.roarracing.com/downloads/2006rulebook.pdf , so I would mount it so roof is at least 130mm high then cut it.
imjonah is offline   Reply With Quote
Old 09-30-2006, 11:46 AM   #4
That seems really high. I have a DNA1 body. With the body 9mm off the ground near the center the roof is about 115mm high.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Trimming Foam Inserts battlecat3 Electric Off-Road 2 04-15-2008 11:13 AM
Trimming Crankshaft??? hav_lova Nitro On-Road 5 01-13-2006 08:49 PM
Trimming Bottom of Lexan Body imjonah Painting, Designs, Graphics and Photography 1 11-07-2003 06:31 PM
trimming body for height off track imjonah Painting, Designs, Graphics and Photography 2 10-26-2003 03:45 PM
R.O.A.R. Question (body trimming) hicheef Nitro On-Road 32 09-12-2003 08:39 AM
