Old 09-29-2006, 02:33 PM   #1
Default best way to charge 4200
Can anyone try my set-up step charging.
1. 3850 mAh 6A.
2. 3900 mAh 0.2A.
3. 4800 mAh 4.5A.
flex off
5 mV cut off
temp 50
I found that just like linear charging,same volt.but very good for take care my pack.temp cut off lower than linear charging.more mAh and lower IR.I just want some response.
khunballz is offline   Reply With Quote
Old 09-29-2006, 05:26 PM   #2
Tsquare's Avatar
1. 3850 mAh 6A.
2. 3900 mAh 0.2A.
3. 4800 mAh 4.5A.
flex off
5 mV cut off
temp 50
When I step charged my IB's I did not notice a big difference in performance, or battery temp. In fact, I have more problems getting my temp into that 125 to 130 temp range (farinheit), So I usually charge my IB 's linear at 6amp.
Tsquare is offline   Reply With Quote
Old 09-29-2006, 10:42 PM   #3
PitCrew's Avatar
Best way to charge:
Connect the IB4200 pack directly to a 12v car battery. You will know the pack is charged when it starts to make a slight hissing sound. Immedietly disconnect the battery then.
PitCrew is offline   Reply With Quote
Old 09-29-2006, 10:55 PM   #4
C_O_jones's Avatar
Originally Posted by PitCrew
Best way to charge:
You tell him Smokey!
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 09-30-2006, 02:03 AM   #5
anyone try this? i'll test my step charging at the track tomorrow.
How to charge 4500mah? Toonz Singapore R/C Racers 2 12-14-2007 03:55 AM
How to charge IB 1400's BimmerDriver Micro and Mini Scales 4 01-24-2007 07:03 PM
East Power 4200 Charge info? aus jd 2703 Electric On-Road 4 06-19-2006 08:25 AM
20 AMP DIS CHARGE .6 CUT OFF DIMO Electric On-Road 0 06-29-2005 05:49 AM
charge sean Electric On-Road 2 03-21-2004 09:05 PM
