Old 09-27-2006, 01:03 PM   #1
Trader Rating: 54 (100%+)
Default KO Helios ESC max
For my Helios, should I set my throttle and brake maximum to 100 as per my ESC's instruction manual or use the 150 maximum setting on the radio?
I believe my M8 maxed out at a 100 (not 150 as the Helios) so I never ran into this problem before.
WHOBEE is offline   Reply With Quote
Old 09-28-2006, 05:27 AM   #2
BrainTeased's Avatar
hi
you can set the transmitter at 150 for both the throttle and brake high points.
what some do is set it at 140 when setting the ESC, and then after the esc setup set the transmitter settings to 150
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-28-2006, 06:16 AM   #3
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Yea and some ESC will let out the smoke if you do it.
Ko Propo recommends that you set the throttle to 100 when setting up a VFS 1 ESC and says that you shouldn't change that setting higher than that or damage may accoure...Just wanted to make sure you have all the info...
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
KO HELIOS, GFX, MUCH MORE, ETC. EVILGRAFX R/C Items: For Sale/Trade 24 11-02-2007 02:17 PM
KO Helios II Fast R/C Items: For Sale/Trade 28 09-13-2006 08:27 PM
Helios Ill Factor R/C Items: Wanted to Buy 0 05-03-2005 12:48 AM
helios hpipro321 R/C Items: Wanted to Buy 1 11-24-2004 10:24 PM
helios/3pk ntc3freak Malaysian R/C Racers 14 11-11-2004 09:29 PM
