Old 09-24-2006, 09:57 PM   #1
PeteB's Avatar
Default How hot is too hot?
Hello people,
Does anyone know at what temprature a motor will suffer heat damage. I recently installed a temp sensor into my heat sink and can get real time temprature readings. I now need to set a "high temp" warning alarm, so that when the motor gets to a certain temp it will alert me.
Pete
JRXS-R
GTB SS + 13.5 & 10.5
Trakpower 4900
Supernova
Nomadio
PeteB is offline   Reply With Quote
Old 09-24-2006, 11:18 PM   #2
drew85's Avatar
Does it burn your finger in about 1 second? its too hot. I think its around 140 150?
drew85 is offline   Reply With Quote
Old 09-25-2006, 01:03 AM   #3
PeteB's Avatar
Sensor was giving a reading of 75c (168f) and was pretty hot, so I may have cooked the motor, so maybe setting a warning at 60c (140f) might be appropriate...
your thoughts?
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 09-25-2006, 02:07 AM   #4
temp reading on heat sink (clip on) may lower than actual on motor body,
so I think 60C is pretty safe number, regardless Brushed or Brushless motor,
though my Tamiya TZ 23T Stand Up stock motor which is best geared around 5.5 FDR would usually come from track about 75 C (still at good condition) ,
Faiz is offline   Reply With Quote
Old 09-25-2006, 02:35 AM   #5
Birky's Avatar
My general rule is to gear it to it smokes and then drop back a tooth.
In all seriousness, I follow the general rule that drew85 suggests, where if you can't hold your finger on the motor for 1.5 - 2 seconds then its probably too hot.
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 09-25-2006, 02:58 AM   #6
Dadaman's Avatar
Trader Rating: 20 (100%+)
My Mrs uses mine after a race meet to cook the eggs for the kids that night.
Xray XB4 '16
Yokomo Dogfighter YZ-10 870c
Xray T4 '14
Dadaman is offline   Reply With Quote
Old 09-25-2006, 03:27 AM   #7
asw7576's Avatar
I always check the color of the comm. If it turns purple, I know its too hot.
Old 09-25-2006, 03:36 AM   #8
PeteB's Avatar
Originally Posted by Faiz
temp reading on heat sink (clip on) may lower than actual on motor body ,
Thanks for your input Faiz, the sensor is installed inside the heatsink and does not have air flow over it, but yes I would expect it to be a few degrees lower. I have to pick an actual temp figure to input into the system, so maybe 60c will do until I figure out something else.
Comm is ok, the wind indicator (not sure what it is made of) is slightly burnt around the edges
Has anyone ever used an infra red temp sensor to measure the surface temp of a motor just after it has overheated and cooked itself?
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 09-25-2006, 09:09 AM   #9
asw7576's Avatar
98C with exergen, measured right away after 8 minutes race. Motor was Yokomo LT with 5 FDR, but did not check the color on the comm.
Old 09-25-2006, 09:32 AM   #10
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
My motor was...was.....was...... 240 degrees imediately after it burned/smoked. I think something got caught up inside of it. It was running fine, when I rolled over a corner dot and suddenly went slower. As I pulled off of the track, holy smokes.
I've had motors go upto 181 degrees (not by choice) and still survive. At 210 degrees I noticed loss of power, comm was okay but magnets loss power. I think 145 is a safe temp to be at. Any time I loose power towards the end of a run, the motor has reached 160 or more. Hope this helps.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 09-25-2006, 01:36 PM   #11
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
as long as the tag is the same white color after a run, the comm is is a nice copper, not orange, and the motor doesnt really fade i dont worry about motor temp. i gear for the point where it winds out on the straight about 3/4 the way down. i have had very fast stock motors in the 175*f range with little issue, and it wasnt detremental to the overall performance.
-Zac
Z.Hallett is offline   Reply With Quote
Old 09-25-2006, 07:04 PM   #12
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Too hot is when the motor fades before 5 mins. Some people get hung up on temp, honestly it only applies in gas engines. You won't see any pros using temp guns on electric motors. If it makes it the full race without fade then who cares what the temp is.
P.S. High temps will kill the magnets quicker. That's one main reason you will see magnet zappers at major races.
Anthony.L is offline   Reply With Quote
Old 09-25-2006, 07:38 PM   #13
PeteB's Avatar
yeah, the reason for the question was that the motor I was using was going well, and didnt just 'fade'. it completely stopped (at about 4 min), coming out of a corner it just stopped within a distance of 10m, no warning, middle of the track (car would not move at all), nothing was jammed in the motor, after it had cooled down it seems to work ok again
JRXS-R
Trakpower 4900
Supernova
Nomadio
Old 09-25-2006, 07:42 PM   #14
Trader Rating: 35 (100%+)
Send a message via AIM to Sean R
El hungo brusho?
Sean R is offline   Reply With Quote
Old 09-25-2006, 08:11 PM   #15
Anthony.L's Avatar
Yeah I've had that happen to me before. The motor was way over geared and it got REALLY hot and just stopped until it cooled off then it ran again ok. The easiest way to tell the motor is getting too hot from overgearing is too look for discoloration on the com and brushes, that's a dead giveaway.
