Old 09-24-2006, 09:51 AM   #1
Send a message via MSN to makytc4
Default racing on slippery floor
anyone got any good tips tire/insert combos that they have had good results with. 20mm minpins seem to be the way but what does anyone else think
makytc4 is offline   Reply With Quote
Old 09-24-2006, 10:55 AM   #2
MK_Arbiter's Avatar
Soft tires + soft inserts.
MK_Arbiter is offline   Reply With Quote
Old 09-24-2006, 11:44 AM   #3
sosidge's Avatar
Narrow Yellow Minipins with Blue Schumacher narrow inserts are what I have always used. The softest inserts (white I think) let the tyre roll over a bit too much on the rim.
Setup should be more or less the same as a good rubber/tarmac setup, I would run a diff or a spool in the front (one-way too unstable unless you are super-smooth), remove any anti-roll bars, run maximum droop, and avoid the temptation to go super-soft on the springs and damping as the car just tends to get "stuck" in the corners instead of rotating.
Old 09-24-2006, 12:25 PM   #4
yeah the inserts i was most worried about. i had the same thought as people were saying they were using no inserts but id of thought u would loose the contact patch of the tire as u cornered. thanks a lot
slippery as freestyles Nitro On-Road 9 06-15-2008 02:46 AM
Slippery When Wet tenpins77 Electric Off-Road 11 08-16-2007 09:01 PM
Racing on a rubberized Gym Floor ? morosis Electric On-Road 11 12-22-2005 08:28 PM
1/10 Touring Car and Gym Floor ZippyFastTcGuy Electric On-Road 11 12-21-2005 12:44 PM
Racing on polished floor (basketball court) B4 Electric On-Road 19 09-19-2004 08:24 AM
