Old 09-21-2006, 11:41 AM   #1
TRFTIM's Avatar
Default Saddle packs to sticks
Can I change my saddle packs to sticks as I have a 415 stick pack chassis, and have loads of saddles.
Can this be done??
TRFTIM is offline   Reply With Quote
Old 09-21-2006, 05:48 PM   #2
rtherbe's Avatar
Same # of cells-Same voltage-securely Fits in car? I would say yes.
rtherbe is offline   Reply With Quote
Old 09-21-2006, 06:01 PM   #3
Burlap's Avatar
Send a message via MSN to Burlap
You can, but oh Lord isn't it a pain in the arse making stick packs. Better off selling the saddle packs and buying new stick packs, if you value your sanity.
Burlap is offline   Reply With Quote
Old 09-21-2006, 09:34 PM   #4
Tsquare's Avatar
I agree with this statement, did it once will never do it again.
Tsquare is offline   Reply With Quote
Old 09-22-2006, 02:58 AM   #5
Trader Rating: 69 (100%+)
i suggest either ...
A. get the regular 415 lower chassis plate with slots for your batts. you can install your saddlepacks directly or convert them to side by side - just replace the jumper wire with a battery bar.
or
B. modify your stick pack chassis ...
- 1. get yokomo BD plastic battery trays
- 2. dremel/cut away the protruding plastic under the trays so you can install them flat on the chassis -but check first before cutting away - depending on your cells, you may need to leave the protruding plastic parts behind, just check if your cells are secure enough when the trays are on the chassis.
- 3. CA/epoxy the trays to the chassis
- 4. put a couple of slots on the ends of the battery trays, one on each end. this will serve as your battery tape slot. or you can get a graphite battery strap and aluminum mounts that will fit 6 cells (similiar to what the 415, xray, yoke, etc has) drill a couple of mounting holes on each end of the trays to mount the aluminum standoffs.
IMHO, this is much easier than converting your saddle packs into stick packs
marvi is offline   Reply With Quote
4x saddle packs hailmick Australia For Sale/Trade 1 01-30-2007 10:23 PM
saddle packs rubicon20032003 R/C Items: Wanted to Buy 2 10-03-2006 11:38 AM
Can You Use Saddle Packs , TA-04? Sushi Man Electric On-Road 3 09-13-2005 01:38 AM
Can You Use Saddle Packs , TA-04? Sushi Man Electric On-Road 0 09-13-2005 12:52 AM
Saddle Packs prelude19 Electric On-Road 2 10-13-2001 09:08 PM
