Old 09-20-2006, 03:44 AM   #1
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Default TT-01 Gearing
Hey guys,
just wondering is it ok to run a 55t/28t in a tt-01? or will it overload the motor. At the moment im running 55t/25t and everyone seems to be a little quicker down the straight. And if it is ok to run with anyone know were i can get a 28t pinion??
thanks
surrealmaterial is offline   Reply With Quote
Old 09-20-2006, 06:38 AM   #2
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Originally Posted by surrealmaterial
Hey guys,
thanks
btw what motor are you using??
i have here a gearing chart.. see pix..
nikkiesteban is offline   Reply With Quote
Old 09-20-2006, 10:56 AM   #3
nagatahawk's Avatar
you can run the 28t pinion with the stock silver can motor. Tamiya does not make a 28t pinion. Kawada makes one but you will have to order it thru one of the Japaneses web sites the carries kawada.
It will got hot!!!
nagatahawk is offline   Reply With Quote
Old 09-20-2006, 11:13 AM   #4
larrio's Avatar
It would highly depend on the motor that you are running.
Try switching to aluminum or titanium screws to lighten the weight of the vehicle.
larrio is offline   Reply With Quote
Old 09-21-2006, 02:50 AM   #5
debon666's Avatar
For my TT01 i use 61/22 (7.21) for drifting. And no heat problem for motor and esc. I use Mabuchi TUNED SPORT coz they say its economy stock motor
debon666 is offline   Reply With Quote
Old 09-21-2006, 04:03 AM   #6
im using a stock silver can motor...
Old 09-26-2006, 12:46 AM   #7
will my motor or esc get too hot?? ( i have a heatsink).. and also is the pinion/spur 48pitch?
thanks
Old 09-26-2006, 11:47 AM   #8
lceriyirri's Avatar
I ordered 24/25 poion gears and 55 58 61 surp gear, and I realize that I can't take my poion gear off from the silver can. will I need to remove it by force?
lceriyirri is offline   Reply With Quote
Old 09-26-2006, 10:03 PM   #9
tyler_drift's Avatar
Send a message via Yahoo to tyler_drift
just wanna ask if i can use a 22P/61S for my tt01 with 15t motor? thnx
tyler_drift is offline   Reply With Quote
Old 09-27-2006, 12:38 AM   #10
yeah u can...check out pic....
Old 09-27-2006, 11:19 PM   #11
thnx....
Old 09-28-2006, 01:43 AM   #12
has anyone used a 28t/55t on there tt-01?? And if so..how did it run...did the esc or motor get too hot???
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
