whats wrong with my tc3 >
Old 09-18-2006, 06:34 PM
Tc3Venom's Avatar
Default whats wrong with my tc3
its been running perfect, better than ever latly till today i took it out and it ran with crap. no power, going way slower than normal and steering kept going out it would get stuck turning one way and id drive around in circles for a few secs then it would be fine again. whats up? i think its just an old pos all the stuff on its super old except for motor and batterys...but i dont get the loss of power part! im tired of problems at least im building a new up to date car.
Tc3Venom is offline
Old 09-18-2006, 06:39 PM
Try checking the brushes in the motor. Are you sure the battery had a good charge?
John Warner is offline
Old 09-18-2006, 07:10 PM
Tc3Venom's Avatar
im pretty sure the brushes are fine its only been ran about 4 times on the new motor but ill check them. the batts were charged like 3 days ago...do they lose juice that quick(they were in a basement, kinda cool temp)?
Tc3Venom is offline
Old 09-18-2006, 07:21 PM
thommo09 is offline
Old 09-18-2006, 07:35 PM
James khoo's Avatar
Trader Rating: 15 (100%+)
Hi,what type of charger your using?it best that use the battery just after charging,the voltage will stay at it top,battery will lost it's power every 5 minute 0.2v.hope this help.
Cheers
James khoo is offline
Old 09-18-2006, 07:43 PM
Tc3Venom's Avatar
yea i have a new batt pack and i tried a few. Im using a dynamite peak charger.
Tc3Venom is offline
Old 09-18-2006, 07:50 PM
James khoo's Avatar
Oh,don't forget to check you connections(battery,ESC,motor and receiver)
I had run my Tc3 for years,the only problem i face is too heavy when used with brushless system(1636 grams)
Old 09-18-2006, 08:10 PM
dodo's Avatar
also make sure that it's not a false peak detected.
dodo is offline
Old 09-18-2006, 09:00 PM
Tc3Venom's Avatar
well i cant pinpoint it but since everything is pretty old i think im going to update it since i already got a new motor. Ill totally clean it, rebuilt some stuff, and buy new servo, receiver, and speed control
Tc3Venom is offline
Old 09-18-2006, 09:06 PM
Tc3Venom's Avatar
Tc3Venom is offline
Old 09-19-2006, 05:14 AM
As far as your steering sticking, take apart your steering rack and clean the goo off it. It's a common thing with that style of steering rack. Also...if you have bearings in your rack, switch to bushings. Bearings are useless in the TC3 steering rack.
Stampede is offline
