XXXS droop...........
Quick question, anyone have a way to keep the front bumper from pushing/flexing while setting the droop. I can't go past 3.5mm B4 the bumper starts to flex.
Thanks in advance.
Kevin E.
Thanks in advance.
Kevin E.
Set the droop first, then set your ride height - it sounds like you are pushing against the springs!! The bumper will flex a little bit if you have the old style bumpers - the newer stiff ones don't flex at all
Wilde
Wilde
Thanks for the reply and the tip, have they released the new style??
Thanks in advance.
Kevin
Thanks in advance.
Kevin
Yes they have -
Losi Part #4237 -
Wilde
Losi Part #4237 -
Wilde
WOW you guys rock, thanks for the help.
Kevin E.
Kevin E.
The new bumpers will still flex if you run the low roll center blocks and have the preload adjusters cranked down kinda far as you would have to with small foam tires. To fix this problem run the small droop screws in front when using the low roll center blocks or cut down teh ones you have in.
If i remember right, I put the short screws in the front, and cut the longer ones for the rear, so I did not need to buy a second bumper set.
-T
drooooooop
I dont use droop screws.... took them out..... car handles real sweet
Just let the arms hang
