Old 09-16-2006, 12:40 PM   #1
Trader Rating: 52 (98%+)
Default How do I glue the graphite chassis edge?
Hi, I am new to electric on road. How do I glue the graphite chassis edge? Thanks.
straightaway is offline   Reply With Quote
Old 09-16-2006, 12:49 PM   #2
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Just run a bead of CA on the edges of the chassis and let it sit and dry.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 09-16-2006, 03:32 PM   #3
Tsquare's Avatar
I CA a new graphite chassis by, soaking the tip of a Q-tip with CA and then appling the Q-tip directly to the edge of my chassis. I find it gives me great control, keeping the glue only where I want it to go. This technique is especially helpful if you round the edge of your chassis.
Tsquare is offline   Reply With Quote
Old 09-16-2006, 04:58 PM   #4
fraz's Avatar
Send a message via AIM to fraz
An even better technique is to glue your chassis edges, let them dry, and then shape them. I'll use a file to get it close and then use a blue rubber polishing bit in the Dremel and it comes out nice and round, smooth, and polished. Especially good for carpet cars like 1/12 scale where you run them low and don't want them to get caught.
fraz is offline   Reply With Quote
Old 09-16-2006, 05:36 PM   #5
The best chassis prep instructions I have seen...
http://www.teamcrc.com/crc/modules.p...article&sid=16
duckman996 is offline   Reply With Quote
Old 09-16-2006, 05:45 PM   #6
MATTS's Avatar
I just prepared a chassis myself today for a friend of mine ...
I bassically followed this :
http://www.teamcrc.com/crc/modules.p...rder=0&thold=0
-I Use 320 Emery paper
-then 600x
-then 1000x
-then 2000x
Before applying CA I use a black marker around the edges and it makes a great finish. I tried different kinds of marker and I found the "Shapie" style marker leave a thick residue, I since then swithed to a Avery Marks-A-Lot with the bif wide tip, I find the ink is much better and not as "greasy", dries real fast. dont use the marker over itself just one good run all the way around the chassis.
I used different slightly different way of applying CA, I put a few drops of CA on a Q-tip and run it in the lenght of the edge all the way around, it works but ill try the drop method mentioned in the CRC article the next time I do one.
I round the battery slots using a Dead 3300mah or 3800mah cell wrapped with 320 Emery Paper. file carefully until desired depth is achieved.
Matts.
MATTS is offline   Reply With Quote
Old 09-16-2006, 05:52 PM   #7
Ditto on the most effective way to prepare and GLUE a chassis (great tip).
Fast Faisal
Fast Faisal is offline   Reply With Quote
Old 09-16-2006, 06:28 PM   #8
tbeardmore's Avatar
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
TCS edge chassis for Axial AX10 Mike L. R/C Items: For Sale/Trade 6 03-27-2008 11:32 PM
Leading Edge Hangman Chassis Kit & Crc Pod Plates Mach10_shooter R/C Items: For Sale/Trade 1 11-19-2007 01:42 PM
Leading Edge TC3 Oval chassis kit/conversion - CHEAP! kevin107 R/C Items: For Sale/Trade 9 08-30-2007 11:13 AM
How to remove CA glue? CA Glue on T2R chassis mcgmark Electric On-Road 18 09-27-2006 08:58 AM
Cell slot filing and chassis ca glue service. RCknight Electric On-Road 0 01-19-2006 03:10 AM
