Old 01-05-2007, 09:48 AM   #1411
sinisterRC's Avatar
should the diffirential be tightened out of the box? Meaning should I tighten the differential from the stock settings? I just installed it as it came from the factory. Thanks for the help!
MUGEN Tekno - MBX6TE TEKIN
Custom Nitro Pro Mod
MRX6 under construction..
sinisterRC - High Performance R/C
sinisterRC is offline   Reply With Quote
Old 01-05-2007, 09:58 AM   #1412
ChrisP's Avatar
The diffs come pre-built, but not pre-tightened, they will need to be broken in and tightened.
ChrisP is offline   Reply With Quote
Old 01-05-2007, 10:05 AM   #1413
luke humphrey's Avatar
The diffs come pre-built, do not simply run them in and tighten them. you need to take them apart re-grease them and then run them in and tighten to prefered point
luke humphrey is offline   Reply With Quote
Old 01-05-2007, 11:02 AM   #1414
sinisterRC's Avatar
ok, thanks.
Old 01-05-2007, 12:01 PM   #1415
Default What gears should I run in 19T motor ?
Would anyone tell me what is the spur and pinion gear should I use for 19T while using 58mm foam tire ? I just got my T2 007. Thanks !
X men is offline   Reply With Quote
Old 01-05-2007, 12:25 PM   #1416
teamgp's Avatar
Which brand of 19t motor?
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-05-2007, 01:14 PM   #1417
sinisterRC's Avatar
Is the 007 EU 64p or 48p?
Old 01-05-2007, 01:30 PM   #1418
Checkpoint $$ or can anyone recommend a good motor ?
Old 01-05-2007, 01:31 PM   #1419
it's the us spec, 64p
I am new to 1/10, so please bare with me !
Old 01-05-2007, 01:32 PM   #1420
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Yes
48P
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 01-05-2007, 02:05 PM   #1421
adamge's Avatar
If I'm reading right, Luke claims all new 007 diffs should be taken apart, have grease added, put back together, ran for a while, then tightened. This is the first time I've heard anyone recommend adding grease to the 007 diffs. Is this the right procedure?
-Adam
-Nietzsche
Old 01-05-2007, 02:08 PM   #1422
ghoppa's Avatar
Trader Rating: 54 (98%+)
it's what I have in my '007 & I love it!!! very stong motor for the track we run on....pricey, but worth it, I have run approx 10 packs and will be cutting the comm for the 1st time tomorrow!!!
can't go wrong with it, but there are many other great motors out there as well
ghoppa is offline   Reply With Quote
Old 01-05-2007, 02:19 PM   #1423
Xmen: Check out T-Bang! motors. Great customer service and a Canadian motor tuner as well. His motors are winning all the events on the Canadian west coast from Victoria to Edmonton.
Just click the link in my sig for more info.
Johnny9s is offline   Reply With Quote
Old 01-05-2007, 02:28 PM   #1424
teamgp's Avatar
Go with a 112t spur and pinion sizes 32-35t. Unless its one of the super duper torquey motors, or you're accustomed to riding on rims, you shouldn't need a 36t.
For smaller tracks (less than 100ft straight) and tire sizes between:
* 59.5mm & 60mm use the 32t
* 58mm & 59.5mm use the 33t
* 57mm & 58mm use the 34t
For larger tracks and tire sizes between:
* 59.5mm & 60mm use the 33t
* 58mm & 59.5mm use the 34t
* 57mm & 58mm use the 35t
The target rollouts I've seen have been anywhere between 31mm and 33.5mm, depending on motor torque and track size.
If you use a smaller spur than 112t, the torque from the motor will strip even the hardest of spurs in a hard crash, due to less surface area contact between the spur & pinion.
Also keep in mind that if the brushes are sprung too soft or you have the motor geared too low, then it will heat up easily and *seem* as if you are geared too high. I always try to stiffen the springs, before going to a smaller pinion. The brushes wear down kinda fast and you'll need to shim the springs every 3 to 4 runs.
Guy Hood
Old 01-05-2007, 02:34 PM   #1425
sinisterRC's Avatar
alright If the EU is 48P and a stock spur what pinion would I need to get 6.50 FDR??
