Old 12-25-2006, 06:44 PM   #1321
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
can they do white ?
wallstreet is offline   Reply With Quote
Old 12-25-2006, 06:45 PM   #1322
Xrayracer05's Avatar
Originally Posted by wallstreet
can they do white ?
not sure i have posted the number a few post back. call them.
Xrayracer05 is offline   Reply With Quote
Old 12-25-2006, 08:39 PM   #1323
ghoppa's Avatar
Trader Rating: 54 (98%+)
hey guys, just finished building my US '007 car & I want to know how you all determine what pinion to run based on your tire size. I am a bit concerned on properly selecting the right pinion for 19 turn based on 57mm tires..I'm running it tomorrow
can anyone help????
ghoppa is offline   Reply With Quote
Old 12-25-2006, 08:55 PM   #1324
Hockey 85's Avatar
What 19 turn are you running?
Team Associated - LRP - Reedy - Upgrade R/C - Byron's Fuel - Momentum R/C Racing Team
Hockey 85 is offline   Reply With Quote
Old 12-25-2006, 11:35 PM   #1325
ghoppa's Avatar
Checkpoint....
Old 12-26-2006, 07:51 AM   #1326
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Originally Posted by ghoppa
Checkpoint....
Chekpoints like to roll out in the 33-35 range. You might have to switch to a smaller spur (108) to achieve this type of roll out.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 12-26-2006, 07:54 AM   #1327
teamgp's Avatar
Checkpoint....
With a 116t (64p) spur, start with a 35t pinion. You'll probably end up with either a 36t or even 37t pinion though. Just trying to make sure you don't fry the motor.
With a 112t spur, start with a 34t pinion and you might end up with a 35t or 36t.
For 57mm foam tires, the target rollout should be between 32mm and 34mm.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 12-26-2006, 08:09 AM   #1328
gonzo416's Avatar
Trader Rating: 39 (98%+)
what temp should the motor be after a 5min run?
gonzo416 is offline   Reply With Quote
Old 12-26-2006, 08:10 AM   #1329
WinnipegRacer's Avatar
can anyone help????
I have the same question, but am using a CO27 with 57mm tires.
WinnipegRacer is offline   Reply With Quote
Old 12-26-2006, 09:12 AM   #1330
ghoppa's Avatar
thanks for the info A.Rhoades & TeamGP, but what do you all mean by "rollout"??? is this the amount traveled "per 1 revolution of the motor"????
I have never ran "foams" before and I don't want to over think the whole methology about it....I just can't afford to "fry" a motor (know what I mean??? X-Mas killed by checkbook this year)
anybody have a rollout chart for foams????
thanks for the info!!!
Old 12-26-2006, 09:27 AM   #1331
For a Co27 on a med size carpet track you will want to be around 31-33 pinion w/116 spur.
sizzler is offline   Reply With Quote
Old 12-26-2006, 09:28 AM   #1332
Yes, amount of distance car travels per one revolution of the motor.
Rollout = Tire Diameter X 3.14 / FDR (Final Drive Ratio)
This is a great site for reference - www.gearchart.com
Retired from RC....
Old 12-26-2006, 09:36 AM   #1333
ghoppa's Avatar
awesome!! Thanks again..
last thing: can you give me a good starting point (rollout) for stock & mod foam as well (based on 57mm tires)
thanks A. Rhoades
Old 12-26-2006, 09:36 AM   #1334
Joel Lagace's Avatar
Save some time and math...... www.gearchart.com Print the charts for foam and rubber any config u need.
And dont forget the 007 comes with roll out charts in there setup book
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-26-2006, 10:09 AM   #1335
I ran into a little challenge with the stock 116t spur, I believe a 35t pinion was as large as I could go.. So, I'd recommend a 112t spur for the smaller tire sizes..
www.RCAmerica.com - XRAY - HUDY - Max - JACO - KO PROPO
Darint is offline   Reply With Quote
