Old 12-24-2006, 02:28 PM   #1291
Send a message via AIM to R/C Anonymous
Originally Posted by Deves
Has anyone tried the US edition on Asphault? How does it handle?
Also does the 3200 Lipo's fit on the US chassis?
i ran the Us'007 for rubber class up here and it worked just as good as anything else.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-24-2006, 02:31 PM   #1292
Originally Posted by dal bains
http://www2.towerhobbies.com/cgi-bin...?&I=LXDLV1&P=7
This is what a lot of people used on the T2 with jaco foams.
Used them at the carpet nats last yr and it was a tight fit for the roar tech box but it fit.
I prob have 2 full sets of them somewhere here, i wont run foams again...
$12 a set shipped, one is brand new and the other was used for about 5 races. I will have to find them to confirm I still have both..
XRay makes thicker offset hexes also now if anyone didn't know. I put the +.75 ones on the front with a tiny shim and my Jacos work fine.
Geoff C.
Old 12-24-2006, 02:33 PM   #1293
JimmyMac's Avatar
Originally Posted by rcracenut
Each of you have a good point or idea. Its just that if they are going to "label" it a foam car, it should have what it needs to run the foam tires on it or with it. We ended up putting a couple shims in the hexs to make it clear (barely) but It affected the handling to the point of losing a couple tenths on the best lap time. It effected the steering geometry some I guess. The idea of lowering the steering travel (then building more steering into it) sounds as though it may be the best attempt. Thanks for your help. Dont get me wrong. I am not totally dissapointed with the car. Just surprised by that discovery.
Alot of cars will rub on the shock retainers. Like others have suggested, just run in inner shock hole on the arm. Then turn the dual rate or endpoints down. You shouldn't be running full lock to lock anyways. If you are, your car my not be setup right. And you are scrubbing off alot of speed in doin so.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-24-2006, 07:37 PM   #1294
gonzo416's Avatar
Trader Rating: 39 (98%+)
the rims rub the rear shocks also. what handling characteristics change when moving the shocks to the inner hole?
gonzo416 is offline   Reply With Quote
Old 12-24-2006, 07:44 PM   #1295
Gravity RC
Gonzo: Chris p hit the nail on the head. it sounds technicial with lets say 4.75mms ride height, but as all that means is that it cleared a 4.5mm tech bar but it did not clear 5mm on my guage, so on a set-up sheet i would put down 4.75mm.
Pro tech: I agree that the x-ray graphite could be stiffer but i think that their is alot to be said for consistancy of the flex, now im not saying that this is a proper compairison and trust me I have a Ton of respect for your apinion but here it is. they make very thin spring steel t-bars that are about as stiff as a .73 t-bar but no one runs them because they work so much differently. I figure that the flex of a thicker peice if graphite is much more consistant and returns smoother than the same amount of flex in a thinner peice. Im not saying that im totally right but their has to be a reason because the car works very well with it.
Paul L is offline   Reply With Quote
Old 12-24-2006, 08:10 PM   #1296
protc3's Avatar
Trader Rating: 13 (100%+)
i would agree with you paul if the material actually did return from a flex.it will hold twist.try twisting the top deck and then put it on a flat plate.it turns into a pretzel.i am not really sure what they are using but it is very strange.it has alot of the characteristics of G10 fiberglass.standard component grade doesnt hold a twist like that.the car does seem to be working well.i dont think that was incorperated into the design but it seems to be working.i think it was cost cutting honestly.it allowed them to use thicker material and pocket the chassis and not increase cost.save in one area,spend in another.i think it worked out good for them and they didnt have to increase cost.i dont think they went as deep as you think in the design.just my .02
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-24-2006, 08:21 PM   #1297
Gravity RC
we will agree to disagree but you know i personally respect your opinion, thanks paul.
Old 12-24-2006, 08:40 PM   #1298
protc3's Avatar
cool.see you at the birds bro
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-24-2006, 10:48 PM   #1299
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I just wanted to say thanks to Paul L i was up at trackside today and he went above and beyond to help me get my new 007 ready so i could get a few packs in. The car was fantastic, couple adjustments still to be made but i was very impressed.
Thanks again Paul
wallstreet is offline   Reply With Quote
Old 12-24-2006, 11:50 PM   #1300
Korey Harbke's Avatar
Paulie is the man!!! I can't wait for the novak... first big race on the new team. It'll be awesome!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-25-2006, 01:43 AM   #1301
Deves's Avatar
Jason. When is your asphault chassis for the T2 007 coming???
Deves is offline   Reply With Quote
Old 12-25-2006, 05:22 AM   #1302
protc3's Avatar
i will be working on something right after the birds. merry christmas guys
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-25-2006, 07:35 AM   #1303
rcracenut's Avatar
Trader Rating: 52 (96%+)
Originally Posted by ottoman
Chuck we ran the same car on the same track with you last night... we didnt shim anything nor make any adjustments to work with 28mm foams. If you had a problem why didnt you come over and ask me about it? I was so bored I was helping a guy get his TC3 working What brand tires were you running?
We didnt discover the problem till just before the main. Nicks best went from an 8.4 to a 8.8 by shimming the wheel. I too was helping another guy with his TC3. I had Jacos on.
____________________________________________
1 Corinthians 10:31 ...whatever you do, do it all to the glory of God.
S&N Trackside Hobbies
Innovative Hobbies and Raceway
Clark RC race park
rcracenut is offline   Reply With Quote
Old 12-25-2006, 10:58 AM   #1304
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'll be glad to test one up here in Sacramento...
If anyone wants to try out the set up I ran on carpet with rubber tire's.....it's on the Xray site and on www.gearchart.com
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-25-2006, 11:12 AM   #1305
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
How did the oneway feel on carpet, never tried that.
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
