Old 12-21-2006, 09:52 PM   #1261
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Originally Posted by XMSRacing
I have to laugh... and this means absolutely no harm to anyone that chimed in and posted info up on this thread in the last couple posts.
I asked about a lighter one way - and got all sorts of info on spools.
Non taken bro....it goes like that...one tries to help than the rest of know it all's chime in...
As far as I know there aren't any lighter oneway units except the new center oneway that hollows out the layshaft. At least that is what I was told it woudl be.
Sorry about not answering your ???
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-22-2006, 08:14 AM   #1262
teamgp's Avatar
As far as I know, there isn't anything lighter than the OEM multi-diff. However, it is a misconception that it is heavier, in one-way config, than a ball diff.
You can lighten it up an extra gram by using titanium screws to mount the pulley on.
Keep in mind that the layshaft one-way will be heavier than the solid layshaft, given that it has aluminum pulleys and one-way bearings.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 12-22-2006, 08:50 AM   #1263
XMSRacing's Avatar
Trader Rating: 11 (100%+)
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Thanks to everyone for the info. Can't wait to get everything together and get back on the track.
XMSRacing is offline   Reply With Quote
Old 12-22-2006, 11:21 PM   #1264
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
silly question for those running the 26mm Jaco Wrap tires... what diameter would you start them at for club racing, and also for larger events?
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 12-22-2006, 11:56 PM   #1265
Greg Etter's Avatar
Anyone out there using a KO 2413 servo? It dosen't look like the servo arm/horn will work with that servo. When the arm passes over the body of the servo it will rub the top of the servo case. Am I doing something wrong or do I need to use a different arm with that servo? Any help would be appreciated.
Thanks...Greg
Greg Etter is offline   Reply With Quote
Old 12-23-2006, 06:51 AM   #1266
adamge's Avatar
Turbonium, in the RC ONroad subforum there was a recent thread titled something like 'foam tires for dummies.' In this thread someone got into those most detail I've seen regarding wraps and using them, including diameters.
-Nietzsche
Old 12-23-2006, 07:21 AM   #1267
Thanks...Greg
Hey Greg,
I use the KO servo. I too had the servo arm rub on the servo case.
I got the linkage as straight up and down from the servo arm, it still had a minor rub. I tried with a 1mm shim behind the servo horn, but it seemed that it wouldn't hold if I took a major hit, so I took out my dremel and just sanded off a little bit of that nub on the servo horn to just let the servo horn not rub.
I hope this makes sence.
-Shookie <><
Get the linkage as straight 90* as possible first as this going to make sure your throws are equal.
Old 12-23-2006, 10:53 AM   #1268
Gravity RC
Turbonium: here is where i have been running mine lately.
Big race, 56.5mm or 2.225in
Club race,57.7mm or 2.270in
and this is for the 36mm jaco wraps.
Paul L is offline   Reply With Quote
Old 12-23-2006, 10:56 AM   #1269
THeGame's Avatar
Send a message via AIM to THeGame
Chuck is this a new jaco tire 36mm wrap..??
THeGame is offline   Reply With Quote
Old 12-23-2006, 10:56 AM   #1270
Greg Etter's Avatar
Mr. Shookie
Just so I understand did you use the black horn (k) that is supplied with the kit or the white horn that you get with the servo? If you used the black horn (k) when you dremeled the nub did you also have to dremel some off the ball stud so it wouldn't rub too?
Thanks...Greg
Old 12-23-2006, 12:02 PM   #1271
gonzo416's Avatar
Trader Rating: 39 (98%+)
how are you able to measure 57.7? are you using a digital tire truer (if so what brand and model) and the same for droop and ride height, some people use 1/4 increments. where can i find a ride height gage that measures in 1/4 increments?
gonzo416 is offline   Reply With Quote
Old 12-23-2006, 12:29 PM   #1272
Turbonium's Avatar
and this is for the 26mm jaco wraps.
thanks Paul... i was thinking around there, 58 to start was my plan, as our local track is fairly low bite.
see ya in a few weeks!
Wes
Wes
Team Novak
Old 12-23-2006, 02:07 PM   #1273
ChrisP's Avatar
Measure with a calipre...and make fine adjustments with the truer until you reach the set point you're looking for...keep checking with calipre in between cuts...
ChrisP is offline   Reply With Quote
Old 12-23-2006, 02:17 PM   #1274
gonzo416's Avatar
what about the ride height gage.someone i talked to said he has one but doesn't know who makes it and on alot of the setups guys use 1/4 increments
Old 12-23-2006, 07:06 PM   #1275
XMSRacing's Avatar
The Hudy one goes to .5 - never seen one down to .25's.
You could quite easily eye ball the Hudy to a .25 of a mm with those markings though.
