Old 12-17-2006, 09:29 AM   #1216
Hockey 85's Avatar
Well I recently got an xray T2 '007 EU edition and my kit seems to be missing the the balls that go into the top of the shock to screw into the shock tower. Am i missing something? My kit came with 4, and that is enough to do the bottom eyelets but not the top. It is part #3032341 if that helps. Did this happen to any of your '007's? It also says in the instruction manual that is only supposed to come with 4. So am i doing something wrong?. Thanks any help will be appreciated
Team Associated - LRP - Reedy - Upgrade R/C - Byron's Fuel - Momentum R/C Racing Team
Hockey 85 is offline   Reply With Quote
Old 12-17-2006, 11:07 AM   #1217
Joep's Avatar
If you miss anything the best way is to mail to [email protected]
Xray T3 for dry and Xray T2'009 for rainy weather. Sponsored by: Myself and my wife.
Joep is offline   Reply With Quote
Old 12-17-2006, 02:26 PM   #1218
imr
imr's Avatar
how can I get faster left/right direction changes?
Running silver/gold springs 30 wt around.
Should using a front sway bar help?
imr is offline   Reply With Quote
Old 12-17-2006, 02:41 PM   #1219
Send a message via AIM to R/C Anonymous
Originally Posted by svines1972
Does 114/33 - 5.87 ratio sound like a good starting point for gearing? Rubber/Carpet/CO27
On our local carpet alot of guys gear their CO27s from 7.5-8.2 with rubber tires. That's with a 75 foot straight and somewhat tight corners.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-17-2006, 04:26 PM   #1220
gacjr0's Avatar
Trader Rating: 15 (100%+)
hello all,
Will this alu middle one way help like it says for rubber carpet/asphalt?
http://www.teamxray.com/teamxray/new...20Pulley%20Set
Does anyone have experience with this?
Thanks,
Gary
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 12-17-2006, 07:07 PM   #1221
Nexus Racing's Avatar
R/C Tech Elite Subscriber
Without knowing anything else about your setup, I'd suggest standing up the front shocks some (a more outer hole on the tower)...that should make the steering more agressive.
Adding a front sway-bar can take you either way, depending on what your car is really doing. It can sometimes remove enough front grip that your steering response becomes even worse.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 12-17-2006, 08:43 PM   #1222
Gravity RC
I think that Nexus is right with everything he said but if you are looking for a more specific answer please post more about the surface and tires which you are running, and more about your current set-up.
thanks paul
Paul L is offline   Reply With Quote
Old 12-17-2006, 09:00 PM   #1223
Greg Etter's Avatar
Paul L.
Got any suggestions for a asphalt/rubber setup for the EU 007. Most everything I see right now is for carpet.
Thanks......Greg
Greg Etter is offline   Reply With Quote
Old 12-18-2006, 04:20 AM   #1224
imr
imr's Avatar
Thanks Nexus and Paul,
I was looking especially on some general setiings I could try and give me the most result so I could work on that. Looking also for some overall grip, it is a low to mid traction, technical track so I have tho be able to make fast changes and also go fast through the corners.
I got a good setup at this moment, just looking for that edge.
Old 12-18-2006, 07:26 AM   #1225
STLNLST's Avatar
Trader Rating: 21 (100%+)
thanks paul
On carpet with rubber tire's have you ever tried running a spool? I'm just curios if having breaks in mod would be a big help if the track has a sort of high speed 180. Or is it better to just have the oneway set up dialed? I'm just looking for a bit more off power steering. I'm running your complete set up except for the rear shock oil (still waiting for my 25wt oil) and the rear camber link location. I went down one hole for traction. Linda said my oil will be to me for next weekend race. Also....does the antidive take away a little of my off power turn in?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-18-2006, 11:43 AM   #1226
Suspended
What up Homie, The Anti Dive is just what it is, It wont let the front dive ,go to a softer spring in front . You might want to go even softer ,like two spring rates , hope this helps..Bitter
CAlbrecht is offline   Reply With Quote
Old 12-18-2006, 12:00 PM   #1227
STLNLST's Avatar
I WAS THINKING ABOUT THAT. THANKS FOR THE INFO. YOU COMING UP FOR THE TWO DAY RACE? THE BRUSHED MOTORS UP HERE ARE JUST AS FAST AS BRUSHLESS. MY KD IS STILL THE FASTEST BRUSHED 19 OUT THIS WAY AND IT FELT BETTER THAN MY BRUSHLESS. EA KNOWS HIS STUFF
Old 12-18-2006, 01:46 PM   #1228
Suspended
Nope. Look at my sig..... Selected carpet events like Mr. Francis... See ya @ Tamiya..Keep bangin ...Bitter
Old 12-20-2006, 09:11 AM   #1229
Irrelevant with this topic but, Xray goes Nitro 1/10
http://www.rctech.net/forum/showthread.php?t=141149
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 12-20-2006, 09:33 AM   #1230
sukh's Avatar
I wanted to know the effects of using or not using the o ring on the shock shaft, it asks you on the set up sheets and never really figured out the effect.
sukh is offline   Reply With Quote
